Building Linux and FLOSS programs from source code
There are several options in /etc , and I dont claim to understand it.
It seems to depend on which services you have installed.
Of course - if you change /etc/environment - you need to either logout - or reload your profile…
Pretty sure .profile reads /etc/environment (and /etc/profile)… maybe as an undocumented ā€œincludeā€?
Also note : this was on server environments - but worked on all the DEB and RPM families I’ve used that on…
However - I don’t think you can append to existing $PATH with /etc/environment - i.e. ā€œPATH=$PATH:/dir2:/dir2/ā€ doesn’t work (I think?)
Shame it can’t be more consistent… Oh well…
Will give this a try!!!
There is no /etc/environment in LFS but there is a .bashrc.
Yeah, it varies between distros. Some of mine have /etc/profile.
Do the user one, it is easier.
There are 2 files where settings can be added or modified in each user’s home directory. They’re dot files so you need to use ls -a to see them in the directory. There’s a .profile file that runs when you log in and a .bashrc file. Usually, the path is set in one or the other.
Yes, I used the .bashrc, for my user account and bashrc for my root account.
With LFS I have to use ā€œls -laā€!!
The main problem I am having now is with the mesa install!! My old Nvidia GT430 and the libglvnd, is nowhere to be founf for LFS12.3, so I have switched to my onboard Intell HD4000, for my GPU and am rebuilding llvm in hopes of getting the dependencies needed for Mesa.
If I cannot get a Mesa compile, then I would have to use an older version of LFS!!
Started updating and rebuilding some of the older packages on my system. Here’s a list of what I’ve been building: https://lmemsm.dreamwidth.org/33313.html If anyone wants to compare notes, please post.
I had a look and I see where you are headed
ā€œOnce I have a compiler, core utilities and basic build tools in place, I build libraries and programs in these four categories: archive, communications, graphics, audio. After that, I typically build my graphics/GUI libraries. Then I build applications that use those GUI libraries and my audio and generic cli programs. On Linux, I build X11 libraries before building GUI libraries.ā€
When you go to put these components together, how do you stand on things like dbus, polkit, elogind or consolekit or turnstile, pam.
I find authentication and permissions to be a maze of barriers hampering me from doing things. Are they really necessary in a single user home PC , and can I set up a system without them ( eg like hyperbola linux)
When you get to the app stage, you are going to have to decide how apps interact, with the kernel and with other apps. I would vote for open access and interaction rather than security, but it depends on your target.
Dreamwidth is fascinating.
I typically concentrate more on the libraries, compiler and applications I want to run and don’t delve as much into the lower level parts of Linux. I build applications for a variety of operating systems, so many of those issues just don’t exist on other operating systems. Right now, I’m investigating using the Linux kernel with Busybox. I also typically run my Linux system offline and sneakernet applications to it. So, I’m not as concerned about security. I do have an article at my site about replacements for sudo. With the new development in Rust for sudo, it turned out to be useful to find some alternatives. I’m also using Busybox, sbase, BSD and Minix programs, plus a few of my own to replace core utilities. I’m trying to keep the number of interpreters and other compilers on the system down to a minimal and mainly working with C and C++. I haven’t had any issues with the programs I’m running needing higher level permissions or authentication to date. However, I run a lot of lightweight, non-standard programs. I’m experimenting with using an older version of X11 similar to what TinyCore Linux does. Glad you enjoyed my articles on Dreamwidth.
Have you seen smolBSD?
Do you have an opimion on that?
I am thinking of trying a BSD from source build. … just kernel and utilities … no DE.
Haven’t tried smolBSD. I did like some of the programs in PicoBSD a while ago, but development hasn’t been active for a long time. I recently built NetBSD on Linux and I’m running it in a virtual machine. Was thinking of trying to build the same libraries and programs on that system and see how it goes. I’ve read that NetBSD is fairly easy to build from source, plus it works with several types of CPUs and offers 32 or 64 bit choices.
Yes, NetBSD would be one of my choices to try a build.
I think any BSD build would be simpler than linux
I am leaning towards a manual effort ( like LFS) rather than something like smolBSD.
Thanks for comments.
To build NetBSD, I downloaded netbsd-11.0_RC1-i486-1l32.tgz, sharesrc.tgz, gnusrc.tgz syssrc.tgz I think I ran ./usr/src/build.sh -m i386 -U -O obj -T tools release Ended up with a netbsd.img file in the release directory. If you want a 64 bit system, you’d need to download the appropriate files and run commands to build that. It took about 5 1/2 hours to compile. The image file seems to work well with qemu.
If you want to compare notes on building source on NetBSD, let me know.
