Cannot get "barrier" to work
Hi and thanks for your post,
having downloaded synergy-v1.8.8-stable-Linux-x86_64.deb from your link (thanks for that)
I still couldn´t install it. A variety of packets have unfulfilled/unmet dependencies.
Just as an example: libqtcore4 […] but cannot be installed.
There are three more of those.
Never mind. Thanks anyway.
Greetings.
where did you get a package for 18.04? i looked and only saw one for 20.04.
Hi,
I followed the link @daniel.m.tripp provided:
https://www.brahma.world/synergy-stable-builds/ .
And there: https://github.com/brahma-dev/synergy-stable-builds/releases/download/v1.8.8-stable/synergy-v1.8.8-stable-Linux-x86_64.deb
Cheers.
Rosika
i should have been more clear with my question :slight_smile: i was trying to find a barrier package for 18.04 to test and see if i run into the same difficulties you are having. i saw packages for 19.10 and 20.04 on the parent page of where you posted your support request. i did also see a snap and flatpak available, but was wondering if you had come across a package specifically for 18.04.
Did you run “sudo apt -f install” after you got unmet dependancies? Even installing Pro version I have to do that after installing the DEB file with dpkg command…
@daniel.m.tripp:
Hi,
thanks for your suggestion. I didn´t run “sudo apt -f install”.
It didn´t occur to me as the remark “but cannot be installed” threw me off.
I´ll try that and report back as soon as possible.
Thanks again.
Cheers.
Rosika
Hi again,
in the meantime I ran “sudo apt -f install” but it changed nothing.
Nothing ro remove, to install or to update.
Again the syngergy installation process says:
Die folgenden Pakete haben unerfüllte Abhängigkeiten:
synergy : Hängt ab von: libqtcore4 (>= 4.6.2) ist aber nicht installierbar
Hängt ab von: libqtgui4 (>= 4.6.2) ist aber nicht installierbar
Hängt ab von: libqt4-network (>= 4.6.2) ist aber nicht installierbar
Hängt ab von: libcurl3 (>= 7.19.7) ist aber nicht installierbar
All those libs cannot be installed.
Well then. At least barrier should run.
And so far I can say it´s the client side which poses problems.
The server side says: “Barrier is running” but the client says: “Barrier is starting”.
So I looked up the logs (from client) which say:
[2020-07-12T14:04:57] INFO: starting client
[2020-07-12T14:04:57] INFO: config file: /tmp/Barrier.TJ2435
[2020-07-12T14:04:57] INFO: log level: INFO
[2020-07-12T14:04:58] NOTE: started client
[2020-07-12T14:04:58] NOTE: connecting to '192.168.2.50': 192.168.2.50:24800
[2020-07-12T14:05:13] WARNING: failed to connect to server: Timed out
[2020-07-12T14:05:14] NOTE: connecting to '192.168.2.50': 192.168.2.50:24800
[2020-07-12T14:05:29] WARNING: failed to connect to server: Timed out
[2020-07-12T14:05:30] NOTE: connecting to '192.168.2.50': 192.168.2.50:24800
[2020-07-12T14:05:45] WARNING: failed to connect to server: Timed out
[2020-07-12T14:05:46] NOTE: connecting to '192.168.2.50': 192.168.2.50:24800
[2020-07-12T14:06:01] WARNING: failed to connect to server: Timed out
[2020-07-12T14:06:02] NOTE: connecting to '192.168.2.50': 192.168.2.50:24800
[2020-07-12T14:06:17] WARNING: failed to connect to server: Timed out
[2020-07-12T14:06:18] NOTE: connecting to '192.168.2.50': 192.168.2.50:24800
[2020-07-12T14:06:33] INFO: stopping barrier desktop process
[2020-07-12T14:06:33] NOTE: stopped client
[2020-07-12T14:06:33] INFO: process exited normally
So it´s basically “failed to connect to server” which is the problem.
Greetings.
Rosika
Do you have to provide the IP address manually or do you use the server’s hostname?
Hi,
I suppose you are referring to my barrier setup.
On the client it looks like this:
Screen name: rosika-e6222 (which is my laptop/client)
Server IP: 192.168.2.50 (which is my PC/server)
Basically I had to enter the server´s IP.
is the server running a firewall?
Run the following
on the Server:
sudo nc -tlvp 1337
on the Client:
sudo nc -vz 192.168.2.50 1337
And make sure the ports are not blocked by a firewall.
@01101111 and @Akito:
SUCCESS!!!
Well I´ll be blessed. It´s the firewall which is the culprit after all.
I wouldn´t have thought. After all this time of exploring and fiddling… :relaxed:
I did think of that in the beginning and switched my firewall off with the help of the GUI (both on the server and on the client) but it didn´t have any effect.
Now I did it with CLI:
sudo ufw disable. And suddenly it works!!! Perfect.
Thank you so much. :+1:
But now I have to figure out a respective rule so that my firewall can keep running.
I know it´s port 24800 which is used.
Thank you so much. :heart:
Greetings.
Rosika :smiley:
ufw allow 24800/tcp
That´s it. It works.
Thanks a lot. I wouldn´t have know the exact syntax (especially the “/tcp”-part).
I did that just on the server.
Seems I don´t have to do that on the client.
I´m so pleased.
Many thanks to all of you for your great help. :clap:
Cheers and greetings.
that’s what made me think of asking :slight_smile: glad to hear you got it all figured out.
The port needs to be opened only on a server. Generally/usually, servers are the ones needing to open a port, because they listen for connections to arrive. Generally/usually, clients connect to servers and need to open only outgoing ports, which are usually open by default, except you are in a high security environment.
Yes, I noticed that too at the time.
Therefore I switched off the firewall altogether with the GUI.
I still don´t know why that didn´t have any effect. So I dismissed the idea which it now turns out
was false.
I see. Thank you for the clarification.
I´m always glad to learn something new (at least for me it´s new :blush:).
Now I understand. My laptop as a client uses an incoming port so it doesn´t have to be dealt with.
Thanks a lot again.
Geetings.
Rosika
Client → outgoing port
Server → incoming port
I think you just mistyped there. :wink:
Oh, seems I misunderstood.
I thought as the server transmits my mouse signal it uses the port 24800 in a way that the signal is sent out.
And on the client side this port is used to receive the signal. So I associated it with “incoming”.
Sorry if I got that wrong.
