Alfred
Maybe, yes. I’ve learned fixing things ordered by their relevance
Is good get some trouble/problems because it is a mandatory “opportunity” to learn more.
The problem always is the lack of time
Alfred
Then it’s not critical enough. Sometimes I simply have to take the time to fix it.
Each problem has a priority …
I created this post at 09 may and solved 28 may … of course, there are other things to do… job and more …
The point is
A forum is an excellent place to share, refresh and learn
I misunderstood, my bad. I assumed you had to fix your PC to continue your work.
No mistake. I have others machines as backup, so this one had a low priority and with either a pendrive or Samba I did do a backup of my own files to keep working
Take care friend!
