Hello
What an impressive read, I never like the idea of when installing an app with Appimage or snap and flatpak all the packaging is thrown in, in a just incase itās needed,
As in Window$ need to find an app in the wide expanse of sites (trustworthy ?)
Thatās why Linux is my choice for my computer,
Tried it once out of ?? , no thanks itās better to find an alternative app than constipate my machine
A small quote from Nicholas Fraser
Mass containerization and alternate runtimes cannot possibly be the future of desktop apps on Linux. If this is really the direction itās going, the future will be so shitty that weāll all end up back on macOS or Windows.
Do you need a blanket for that chill down your back . . .
That Linux has itās own software stores is a big plus, all the different Distros with different versions is exactly what keeps Linux safe and secure from attacks viruses malware etc
Yeah having a centralized set of base level libraries would seem to be a fantastic way to have software compatible with maybe not all but most Distros.
mm (much like Window$) yeah and how easy for some smartipants kid show all the friends look what I can do to Linux mm
If Linux stood proud of what it is and that is what attracted people to itās shores back a decade or more (Its Own way of doing) instead of going into the latest trend or great idea. ( give a break )
Are we fashionistas ?
Stop trying to please this silly crowd who want The GIMP to look like Photoshop etc.
When MOST times these people seek help in forums And never give a Thank You reply or mark the post as solved.
Short time back I moved from GeckoLinux to SpiralLinux inbetween did a bit of hopping found that Gmusicbrowser is not supported in from the Debian family
Could have gone back to EndeavourOS can get all I want and need there BUT I now prefer the much slower pace where I am.
Thatās OK found alternate ways of getting the replaygain tags done so solved, oops sidetracked
While visiting other Distros found that the only way to get Gmusicbrowser was appimage or snap what a shock to find that the music player ( the best on the shelf Thank You )
Normally Gmb is about 2.5 Mb is from Software center
Appimage or snap a huge 3.1.or 3.5 Gb
Just to be clear apart from being massive and soo sloow to start up I found thats not worth the extra baggage and moved on to another distro to stay.
NO if it is not in the software center of the Distro or the (with caution) AUR or OPI itās not on for this machine.
Big no no to Snap, Flatpak, or Appimage
The way to screwing up your install or the Distro or the entire system is really easy go and install anything from anybody and that is a window to ruining all the hard work and long hours from millions of volunteers.
0Oh what happened I just had an episode.
I think I should wear a hat out in the sun.
Kind Regards
artytux
