Firefox browser problem in Antix23
Hi Neville, :wave:
thanks so much for your detailed description.
Well, I have to admit this is pretty much over my head now and I fear I have lost track of what´s going on exactly or what the problem (in simple terms) is at present. :thinking:
I´d be happy to press ChatGPT for some new answers but I don´t know how to put them forward. So sorry, Neville :bowing_man: .
Perhaps some clarification in simple terms would help…
Sorry, I must admit I am recording what I do without explaining.
The story is I can get connman to do deal with 2 ethernet NIC’s in Antix by taking one of them out of its control using a blacklist and configuring it in /etc/network/interfaces.
In Artix there is no /etc/network interfaces. So I am trying to make connman deal with 2 NIC’s, but so far I have failed. I cant see how to stop it making the static ethernet link a default route.
You dont need to do anything with gpt. I will just keep trying things. I have another issue that has diverted me at the moment.
I think connman isbecoming more popular because it deals with Wifi well. I would like to get on top of it.
@nevj :
Hi Neville, :wave:
thanks a lot for summarizing the problem you´re facing at present. :heart:
O.K., but I consulted it anyway. Hope you won´t mind. :blush:
Trying to get some help from whatever source is something worth while, I hope.
Of course feel free to ignore the following, if it might not be purposeful. :wink:
It seems Neville has successfully managed connman in antiX by blacklisting one NIC and configuring it manually via /etc/network/interfaces.
However, Artix, which is Arch-based, does not use the traditional Debian-style /etc/network/interfaces.
Instead, it relies on other mechanisms like connman itself or systemd-networkd (in most Arch-based setups).
Let’s tackle this step by step for Artix:
1. Handling Multiple NICs in Artix with connman
In Artix, connman should still allow you to manage multiple interfaces. The key is to:
  • Assign a static IP without making the interface the default route.
  • Configure the other NIC for dynamic or primary usage.
Steps:
  1. List Interfaces and Services:
connmanctl services
This will show all detected interfaces (e.g., ethernet_abc123, ethernet_xyz456, etc.).
  1. Configure the Static NIC Without a Default Route: Use connmanctl to assign a static IP without specifying a gateway. The absence of a gateway ensures no default route is created for this NIC:
connmanctl config ethernet_abc123 --ipv4 manual <STATIC_IP> <NETMASK> ""
Example:
connmanctl config ethernet_abc123 --ipv4 manual 192.168.2.2 255.255.255.0 ""
  1. Ensure the Other NIC is Used for the Default Route: Set the other NIC (eth1, for example) to use DHCP or static IP with a gateway:
connmanctl config ethernet_xyz456 --ipv4 dhcp
Or for a static IP with a gateway:
connmanctl config ethernet_xyz456 --ipv4 manual <IP> <NETMASK> <GATEWAY>
Example:
connmanctl config ethernet_xyz456 --ipv4 manual 192.168.1.100 255.255.255.0 192.168.1.1
  1. Prioritize Interfaces: If connman still behaves unpredictably, explicitly set priorities:
connmanctl config ethernet_abc123 --priority 2
connmanctl config ethernet_xyz456 --priority 1
This ensures the NIC connected to the internet (e.g., eth1) is used preferentially.
  1. Restart connman: After making changes, restart connman:
sudo service connman restart
2. Manually Configuring NICs Without connman (Artix-Specific)
If connman continues to misbehave, Neville can configure the NICs manually in Artix. Since Artix doesn’t use /etc/network/interfaces, he can use one of the following approaches:
a) Using systemd-networkd (if enabled):
  1. Create a network configuration file for each NIC in /etc/systemd/network/.For the static NIC (eth0):
sudo nano /etc/systemd/network/10-eth0.network
Add:
[Match]
Name=eth0
[Network]
Address=192.168.2.2/24
For the dynamic NIC (eth1):
sudo nano /etc/systemd/network/20-eth1.network
Add:
[Match]
Name=eth1
[Network]
DHCP=ipv4
  1. Enable and start systemd-networkd (if not already active):
sudo systemctl enable systemd-networkd
sudo systemctl start systemd-networkd
b) Using ip Commands in a Script:
If Neville prefers to bypass network managers entirely:
  1. Create a script to configure NICs on boot:
sudo nano /etc/local.d/network.start
Add:
#!/bin/sh
ip addr add 192.168.2.2/24 dev eth0
ip link set eth0 up
ip addr add 192.168.1.100/24 dev eth1
ip route add default via 192.168.1.1 dev eth1
  1. Make the script executable:
sudo chmod +x /etc/local.d/network.start
  1. Restart networking or reboot to apply changes.
3. Debugging connman’s Behavior
If Neville wants to debug why connman is making the static link a default route:
  • Check connman logs:
journalctl -u connman
  • Ensure no conflicts in /var/lib/connman/settings.
Let Neville know these options, and I’m here if more clarification is needed! :blush:
O.K., that´s it so far.
Good luck, Neville, and all the best from Rosika :slightly_smiling_face:
P.S.:
ChatGPT sends you its regards:
All the best to you and Neville! :star2::wave:
I was able to install the ifupdown-ng package in Artix
So now I can use /etc/network/interfaces, like in Debian
I ran into another worse problem… Artix does not name the two ethernet interfaces consistently.
I made another topic on that
Hi Neville, :wave:
thanks for your feedback.
Great.
I read it through and I must say I´m impressed. :+1:
Congratulations on your success.
but I may yet have to abandon connman altogether and let ifupdown control both NIC’s.
Seems to be a good idea, Neville.
I hope it works out alright.
