General rise in CPU temperature
Thanks for the info.
CPU-X is another Linux app that mirrors a lot of the info CPU-Z gives.
It can show GPU temperature - it’s annoying the interface is so tiny - there’s a tab at the top “Sensors” and it will show GPU temp and fan speed etc… I think you need sensors and lmsensors installed to get that feature - I installed all that stuff some time ago with “cooler-control”…
It is worth a look. 50degC… it is working.
That tiny text is madddning. I wonder can you feed it to Conky and get a readable display?
I detest conky… The amount of hours I’ve wasted in the past just to have a desktop widget - where I hardly ever see my desktop anyway… If my PC slows then - I can run diagnostics in a terminal…
CoolerControl works just fine for me - showing CPU and GPU temperature and even VRAM temperature of the GPU :
I want to take a look at that.
