Get rid of Grub bootnext entries
If you have Grub then you might have noticed that,after an update,there are a few new entries with bootnext in it.
These entries do nothing and are only a result of a bug in a new Grub feature.
You can get rid of these by putting this line in /etc/default/grub :
GRUB_DISABLE_BOOTNEXT=true
then open a terminal and do one off the following: (as root)
update-grub
or
grub-mkconfig -o /boot/grub/grub.cfg /etc/default/grub
Bootnext is supposed to be a setting which determines which OS autoboots at the next reboot, for uefi boots only.
It should not need to appear in the grub menu … so yes, that is a bug.
I have not encountered it with my grub setup … it must be a new feature?
It is a long time since we heard of any grub problems?
It used to be a regular thing on the forum.
Do you think maybe AI is taking over these sort of issues?
What kind of bug is it? Does it cause a problem? Or is it some type of minor problem?
Gemini did not seem to believe this was a bug.
The GRUB 2.16 manual says GRUB_DISABLE_BOOTNEXT stops grub-mkconfig from generating bootnext menu entries and disables the 31_efi_bootnext script. Does the upstream documentation distinguish that from whether firmware honors an already-set BootNext value? That seems worth checking before deciding whether the entries are a bug or intended behavior, or changing boot settings based on the forum claim.
AI assisted; checked against the GRUB manual.
Well,bootnext can give you also an error when a new grub.cfg is made after an update.
With that error this cfg file is saved as grub.cf.new.
Not a real problem with removing the old one and rename the new file.
And if you have snapshots they will be included too
Do you mean btrfs snapshots or Timeshift?
Renaming grub.cfg is a bug as far as I am concerned. … unless grub is altered to check for the new name?
Thank you for giving proper reference.
