Headless laptop - does such a thing exist?
Some ideas
  • mount its root partition and chroot into it… if you then do grub-install and update grub from there it will own grub and become the default.
  • supergrub2disk will boot almost anything
  • if you can get the grub> prompt, you can boot it by hand.
Good luck with that.
