did you ever try
and/or something like smartmontools to try and make sure that the disk itself is sound?
did you ever try
Hi. Yes, I have just tried the ābadblocksā method and got the following message: Checking blocks 0 to 7711
Checking for bad blocks (read-only test): 0.00% done, 0.00 elapsed. (0/0/0 errors)
Pass completed, 0 bad blocks found. (0/0/0 errors)
Do you think it actually checked the USB drive since it gave 0.00% done?
As to the smartmontools, I have not tried. I clicked on the link and had a look around but my Linux experience at present does not extend to that. Thanks for getting back, itās taking a while.
Your device is probably broken.
There was a discussion about a very similar situation. You should read that one, as it explains a lot of possible reasons for the symptoms you experience.
Oh dear. Could you roughly point me in the general direction the discussion was held please so I can read it? Thanks
There is a search button in the top bar.
Thanks. I think I have found what you were referring to.
@sheli I am interested in this subject. I would like to suggest three methods which you may tryif you like.to and have not tried already:
click on Disks in main menu. find you USB and click on it . in the right side you will fin wheel s (3rd item) click on it and you will find a list of Menus relating to the disk. You may try all one by one or any selected by you.
in your terminal issue lsblk to find out your drive and the issue the following command
sudo dd if=/dev/zero of=/dev/yourdrive
in your terminal issue the following commands
sudo add-apt-repository ppa:mkusb/ppa # and press Enter
sudo apt-get update
sudo apt-get install mkusb
you will get a prompt click āYESā
Now āmkusbā will ask you if you wish to proceed with the formatting of the data, āStopā will be selected by default. You now select āGoā and click āOKā.
The window will close and your terminal will look like this.
@Sheli SorryI forgot the most important one. It is āTestdiskā This used by forensic. You will have to install it by
sudo apt install testdisk
and after installation in terminal issue: $ testdisk
you may find about it in : https://www.cgsecurity.org
These suggestions probably wonāt work, because the original poster already tried similar methods and it did not work out. I am quite sure there is something wrong with the hardware.
@Akito : yes You are right. There might be something wrong with the hardware.
