How much code in Linux?
In C
main(){}
That’s what I thought too - sure the shortest program code would be in assembler - not a HLL
But will it work without the ‘return 0’?
Why dont you test it?
Something like a JMP instruction to itself.
Would run forever but be short code.
Okay, will try…
We can cheat a little more: The exit builtin being not mandatory in shells, we can say the shortest program in bash (and other shells) is the empty program: $ bash -c "" is equivalent to $ bash -c exit.
For most interpreted/script languages, this rule is true (the end-of-program instruction/builtin is optional at the end of the script), and the same idea can be used:
  • PHP: $ php -r "" or $ php -r exit;
  • python: $ python -c "" or $ python -c exit
  • perl: $ perl -e "" or perl -e exit
So, the shortest program in bash/perl/python/etc. is… the empty string :slight_smile:
