I periodically run ‘fstrim’ in verbose mode. Beginning two or three months ago I noticed that the number of GB reported as trimmed had roughly quadrupled and was frequently near the entire empty capacity remaining in the disk. Yet the log files were not growing nor was the disk filling up. This occurred on three different computers running 20.04 and persists after recently updating two of them (full wipe clean installs) to 22.04.
To investigate this I loaded a command-line utility called ‘fatrace’ which displays disk activity in real time. It showed that there was a tremendous amount of writing coming from Firefox. I made some of the recommended adjustments in FF to decrease disk writes. That helped reduce the size of the trims but they were still 2 to 3 times larger than they’d been, say, a year ago.
My guess is that Ubuntu is doing a lot more logging than it used to though I can’t see any difference in the behavior of the OS. Nor can I see any benefit of the increased writes. I know that modern SSD drives can tolerate a very large lifetime number of writes so maybe I’m worrying about nothing, but the increased writes seem wasteful.
Has anyone else noticed this? What do you think is going on?
