when I close the laptop cover it goes into sleep mode. wakes up when i open the lid. but after a few seconds itself goes to sleep again. my system Toshiba SATELLITE-T110 Kernel: 5.3.0-26-generic x86_64 bits: 64 compiler: gcc v: 7.4.0 Desktop: Xfce 4.14.1
Do not own a laptop but welcome!!!
What is your battery wear condition ? How much backup do you get ?
battery condition is good.
now, I reinstalled “mint”. I found the problem started when I made the updates. but I do not know which update is caused by it. 65 updates appear after the first installation. I want to put this update list here and ask you for your opinion about which issue might be caused.
this is the update list:
Install requested by user
01.23@00:00 ++ Will install python3-apport
01.23@00:00 ++ Will install python3-problem-report
01.23@00:00 ++ Will install libisccfg160
01.23@00:00 ++ Will install libirs160
01.23@00:00 ++ Will install bind9-host
01.23@00:00 ++ Will install dnsutils
01.23@00:00 ++ Will install libisc169
01.23@00:00 ++ Will install libisc-export169
01.23@00:00 ++ Will install liblwres160
01.23@00:00 ++ Will install libdns-export1100
01.23@00:00 ++ Will install libisccc160
01.23@00:00 ++ Will install libbind9-160
01.23@00:00 ++ Will install libdns1100
01.23@00:00 ++ Will install cpio
01.23@00:00 ++ Will install libdjvulibre-text
01.23@00:00 ++ Will install libdjvulibre21
01.23@00:00 ++ Will install libmagic1
01.23@00:00 ++ Will install libmagic-mgc
01.23@00:00 ++ Will install file
01.23@00:00 ++ Will install firefox-locale-en
01.23@00:00 ++ Will install libgs9
01.23@00:00 ++ Will install ghostscript
01.23@00:00 ++ Will install ghostscript-x
01.23@00:00 ++ Will install libgs9-common
01.23@00:00 ++ Will install libgnutls30
01.23@00:00 ++ Will install libmagickwand-6.q16-3
01.23@00:00 ++ Will install libmagickcore-6.q16-3
01.23@00:00 ++ Will install imagemagick-6-common
01.23@00:00 ++ Will install libarchive13
01.23@00:00 ++ Will install libbsd0
01.23@00:00 ++ Will install libgcrypt20
01.23@00:00 ++ Will install libidn2-0
01.23@00:00 ++ Will install libjpeg-turbo8
01.23@00:00 ++ Will install libpcap0.8
01.23@00:00 ++ Will install libssh-gcrypt-4
01.23@00:00 ++ Will install libvpx5
01.23@00:00 ++ Will install libllvm8
01.23@00:00 ++ Will install libnss3
01.23@00:00 ++ Will install openjdk-11-jre-headless
01.23@00:00 ++ Will install openssl
01.23@00:00 ++ Will install libssl1.1
01.23@00:00 ++ Will install python-psutil
01.23@00:00 ++ Will install python3-psutil
01.23@00:00 ++ Will install python-samba
01.23@00:00 ++ Will install libwbclient0
01.23@00:00 ++ Will install samba-libs
01.23@00:00 ++ Will install samba-common
01.23@00:00 ++ Will install libsmbclient
01.23@00:00 ++ Will install smbclient
01.23@00:00 ++ Will install samba-common-bin
01.23@00:00 ++ Will install libsqlite3-0
01.23@00:00 ++ Will install libwebkit2gtk-4.0-37
01.23@00:00 ++ Will install gir1.2-webkit2-4.0
01.23@00:00 ++ Will install libjavascriptcoregtk-4.0-18
01.23@00:00 ++ Will install gir1.2-javascriptcoregtk-4.0
01.23@00:00 ++ Will install linux-libc-dev
01.23@00:00 ++ Will install linux-generic-hwe-18.04
01.23@00:00 ++ Will install blueberry
01.23@00:00 ++ Will install dkms
01.23@00:00 ++ Will install flatpak
01.23@00:00 ++ Will install libflatpak0
01.23@00:00 ++ Will install gir1.2-flatpak-1.0
01.23@00:00 ++ Will install gdb
01.23@00:00 ++ Will install gdbserver
01.23@00:00 ++ Will install gnome-calculator
01.23@00:00 ++ Will install grub-common
01.23@00:00 ++ Will install grub2-common
01.23@00:00 ++ Will install grub-pc
01.23@00:00 ++ Will install grub-pc-bin
01.23@00:00 ++ Will install grub2-theme-mint
01.23@00:00 ++ Will install initramfs-tools-bin
01.23@00:00 ++ Will install initramfs-tools-core
01.23@00:00 ++ Will install gir1.2-appindicator3-0.1
01.23@00:00 ++ Will install libappindicator3-1
01.23@00:00 ++ Will install libdrm-nouveau2
01.23@00:00 ++ Will install libdrm-amdgpu1
01.23@00:00 ++ Will install libdrm2
01.23@00:00 ++ Will install libdrm-intel1
01.23@00:00 ++ Will install libdrm-radeon1
01.23@00:00 ++ Will install libdrm-common
01.23@00:00 ++ Will install lightdm-settings
01.23@00:00 ++ Will install linux-firmware
01.23@00:00 ++ Will install libdevmapper1.02.1
01.23@00:00 ++ Will install liblvm2cmd2.02
01.23@00:00 ++ Will install dmsetup
01.23@00:00 ++ Will install libdevmapper-event1.02.1
01.23@00:00 ++ Will install dmeventd
01.23@00:00 ++ Will install lvm2
01.23@00:00 ++ Will install liblvm2app2.2
01.23@00:00 ++ Will install libgles2-mesa
01.23@00:00 ++ Will install libegl-mesa0
01.23@00:00 ++ Will install libglapi-mesa
01.23@00:00 ++ Will install libxatracker2
01.23@00:00 ++ Will install libegl1-mesa
01.23@00:00 ++ Will install libgbm1
01.23@00:00 ++ Will install libwayland-egl1-mesa
01.23@00:00 ++ Will install libgl1-mesa-dri
01.23@00:00 ++ Will install libgl1-mesa-glx
01.23@00:00 ++ Will install mesa-va-drivers
01.23@00:00 ++ Will install libglx-mesa0
01.23@00:00 ++ Will install mintdrivers
01.23@00:00 ++ Will install mint-meta-xfce
01.23@00:00 ++ Will install mint-meta-core
01.23@00:00 ++ Will install mintreport
01.23@00:00 ++ Will install mintsources
01.23@00:00 ++ Will install mint-translations
01.23@00:00 ++ Will install mintwelcome
01.23@00:00 ++ Will install libnautilus-extension1a
01.23@00:00 ++ Will install nautilus-data
01.23@00:00 ++ Will install libnm-glib4
01.23@00:00 ++ Will install gir1.2-networkmanager-1.0
01.23@00:00 ++ Will install libnm0
01.23@00:00 ++ Will install network-manager
01.23@00:00 ++ Will install libnm-util2
01.23@00:00 ++ Will install network-manager-config-connectivity-ubuntu
01.23@00:00 ++ Will install pix-data
01.23@00:00 ++ Will install pix-dbg
01.23@00:00 ++ Will install libpulsedsp
01.23@00:00 ++ Will install pulseaudio
01.23@00:00 ++ Will install libpulse0
01.23@00:00 ++ Will install libpulse-mainloop-glib0
01.23@00:00 ++ Will install pulseaudio-module-bluetooth
01.23@00:00 ++ Will install pulseaudio-utils
01.23@00:00 ++ Will install python2.7-minimal
01.23@00:00 ++ Will install libpython2.7
01.23@00:00 ++ Will install libpython2.7-minimal
01.23@00:00 ++ Will install libpython2.7-stdlib
01.23@00:00 ++ Will install libpython3.6-minimal
01.23@00:00 ++ Will install libpython3.6-stdlib
01.23@00:00 ++ Will install python3.6
01.23@00:00 ++ Will install python3.6-minimal
01.23@00:00 ++ Will install python3-gdbm
01.23@00:00 ++ Will install qt5-gtk-platformtheme
01.23@00:00 ++ Will install libqt5dbus5
01.23@00:00 ++ Will install libqt5widgets5
01.23@00:00 ++ Will install libqt5gui5
01.23@00:00 ++ Will install libqt5core5a
01.23@00:00 ++ Will install libqt5network5
01.23@00:00 ++ Will install libsgutils2-2
01.23@00:00 ++ Will install slick-greeter
01.23@00:00 ++ Will install libsystemd0
01.23@00:00 ++ Will install systemd-coredump
01.23@00:00 ++ Will install udev
01.23@00:00 ++ Will install libudev1
01.23@00:00 ++ Will install libnss-myhostname
01.23@00:00 ++ Will install systemd-sysv
01.23@00:00 ++ Will install libpam-systemd
01.23@00:00 ++ Will install libnss-systemd
01.23@00:00 ++ Will install ubuntu-drivers-common
01.23@00:00 ++ Will install gir1.2-xapp-1.0
01.23@00:00 ++ Will install xapps-common
01.23@00:00 ++ Will install libxapp1
01.23@00:00 ++ Will install xfce4-xapp-status-plugin
01.23@00:00 ++ Will install xserver-xorg-input-all-hwe-18.04
01.23@00:00 ++ Will install xserver-xorg-hwe-18.04
01.23@00:00 ++ Will install xserver-xorg-video-all-hwe-18.04
01.23@00:00 ++ Will install xserver-xorg-core-hwe-18.04
01.23@00:00 ++ Will install xserver-xorg-legacy-hwe-18.04
01.23@00:00 ++ Will install xserver-xephyr-hwe-18.04
01.23@00:00 ++ Will install xwayland-hwe-18.04
01.23@00:00 ++ Will install libxreaderview3
01.23@00:00 ++ Will install libxreaderdocument3
01.23@00:00 ++ Will install xreader
01.23@00:00 ++ Will install xreader-common
01.23@00:00 ++ Will install xreader-dbg
01.23@00:00 ++ Will install xviewer
01.23@00:00 ++ Will install xviewer-dbg
Which of the above do you think might have caused this error?
I am no expert. Disable any auto suspend
options through settings. You can always choose to do it with a click.
Thank you. unfortunately I have a perfectionist mindset. you’re right, it’s a solution. I will follow your suggestion if I cannot find another solution. thanks again.
Try installing Caffeine Indicator into your install, it will put a clicky in your taskbar that force your laptop to remain awake if you want it to not time out.
thanks… I tried this too but “mint” does not fit the settings I made in any way. it hangs on its own head. For example, according to my settings, it should not go to sleep in any way, but it does. Locks the screen on its own. Even though I don’t set it up like that …
@doctornice,
I had problems with kernel 5.3.0-26 and I need to use 4.15.0-74 again.
My tip may not be able to fix your problem with suspend mode but you can try with different kernel, like 4.15.0-74. probably you already have it installed, only need to choose on grub, during boot
one option for taking a look at system configurations settings that @Tech_JA taught me is a program called dconf Editor. it is available in the mint software manager. when i searched for “suspend”, i was shown several different settings in /org/gnome/setting-daemon/plugins/power. it seems possible that one of the sleep-inactive-timeouts (or one of the other suspend) settings might be the problematic area.
the fact that the support was removed in the old kernels made me think. Does it cause a negativity?
I’ve tried
thanks . I’ve tried. After using it, I write the result.
kernel 4.15.0-74 is LTS and has support up to 2023
Sorry, I don’t know what these errors mean. Could it be related to the USB wireless device?
This might be related, but with one one of the kernels (I believe it was 5.0.0-37) suspend would not work on my desktop. Mint 19.3 Cinnamon. Every time I tried to suspend, the PC would Restart.
After the last patches, the kernel was replaced with 5.3.0-26 and now Suspend works.
i am seeing similar search results as @Tech_JA bout cdc_wdm being related to some kind of usb networking device so i don’t think that should be causing your sleep mode issues.
The problem was partially resolved with the new updates yesterday. That is, the screen wakes from sleep does not come again, but when you close and open the cover once more, the screen comes up.
