Today the city had a terrible rain and therefore a catastrophic flood, it arrived to my home until some point, many neighbors had no luck.
Assuming the worst scenario about this situation: for a MacBook Pro 2012 with Ubuntu Desktop 24:0x LTS was turn off to let me unplug the laptop.
Note the laptop was shutdown after many months 5-6
Once “finished” the disaster the laptop was turn on and take the opportunity to do the following
sudo apt update
sudo apt upgrade <--- some error about a dpkg
sudo apt autoremove
sudo apt autoclean
sudo apt clean
sudo apt update
reboot
But when is restarted appears: a screen with a “purple” background and the left top Linux tux with an exclamation sign and the following message:
KERNEL PANIC!
Please reboot your computer.
Unable to mount fs on unknown-block(0,0)
Well because is not possible reboot (not sure how to do that - I mean, where to write?) was shutdown and turn on with the classic power button, appears the black screen with some options (the first one is Ubuntu) - I think it is the Grub - pressed enter for the first option as Ubuntu but appears the same message
boot off a USB media (e.g. Ubuntu LTS on USB - can’t remember the sequence on a Mac to force boot of something other than the internal HDD / SSSD).
re-install the O/S
Sorry - if a problem looks too finicky (difficult) to resolve - I’ll usually just re-install the O/S - which isn’t a huge issue for me - I don’t lose data as my important stuff is on my NAS or shared in my “self hosted cloud storage solution” (ResilioSync)…
But - if you get a kernel panic with a USB boot - maybe your hardware is failing? That’s unlikely…
Immediately hold down the Option key after turning it on.
This is done with the usb connected from a power on
Some newer macs based on M processors can be different
But this should allow you to restart and install from the usb a linux version.
I remember there was a issue on the cmos battery if left for some time unused, but cannot remember if its a battery you can changé, depends on the manufacturing year
If you can see the grub menu when the laptop boots you could try to boot the older kernel(s). If you can boot to older kernel backup all your personal data and then try to update the system.
Is there an Advance option? Try to login in under an older kernel or recovery like @ihasama mentioned.
I would try.
sudo dpkg --configure -a This finishes interrupted configs sudo apt install -f Tries to repairs any broken deps that might show up sudo apt update sudo apt install --reinstall linux-image-generic-hwe-24.04 linux-headers-generic-hwe-24.04 Should Re-trigger proper kernel setup & initramfs sudo update-initramfs -u -k all Rebuilds initramfs sudo update-grub
Then reboot.
Because you can get a grub screen , you may be able to boot Ubuntu in Advanced/Recovery (ie single user) Mode. Try and boot another kernel or try single user mode.
You may also be able to edit the grub boot sequence (press e)…for example you could change the cmdline boot parameters.
If they both fail, do what @daniel.m.tripp says and boot a usb drive.
If that boots you can mount the Ubuntu filesystem and try to find the problem.
Here is what AI says
" “Unable to mount root fs on unknown-block(0,0)” means the Linux kernel cannot find or load the root file system, often caused by a missing initramfs image after an update, a full /boot partition, or incorrect GRUB configuration. Fix it by booting an older kernel from the GRUB menu, then regenerating initramfs or updating grub"
so you might have a look and see if the initramfs is missing, or if /boot is full.
Even if I voted above for reinstalling, rescuing a completely messed up or damaged system is a special challenge and very exciting, even though restoring a backup is faster and safer.
There is no other opportunity to learn to handle such things.
This update is completely a new item to me, this posting is the first time I have heard of it.
I have never updated initramfs. Is this something I need to know?
