Laptop lan port - not working
@wadesmart
While we wait for Daniel,
It would seem the NetworkManager daemon is not running
We need to see if any other network daemon is running
Could you have a careful scroll thru ps ax and see if you can see any network daemon - it might be called dhcpcd or networkd or wicked or maybe something else. It will probably end in d .
Your wifi must be being driven by some daemon, and we should not start NetworkManager while some other network daemon is running.
Cheers
79364 ? Ssl 0:04 /usr/sbin/NetworkManager --no-daemon
601 ? Ss 0:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
those are the only two I see with network in the name.
Try this :
╰─➀  systemctl status NetworkManager
● NetworkManager.service - Network Manager
     Loaded: loaded (/lib/systemd/system/NetworkManager.service; enabled; vendor preset: enabled)
     Active: active (running) since Mon 2022-02-07 15:40:45 AWST; 4 days ago
       Docs: man:NetworkManager(8)
   Main PID: 1246 (NetworkManager)
      Tasks: 3 (limit: 47903)
     Memory: 13.3M
     CGroup: /system.slice/NetworkManager.service
             └─1246 /usr/sbin/NetworkManager --no-daemon
Feb 12 06:05:51 titan NetworkManager[1246]: <info>  [1644617151.0401] manager: NetworkManager state is now CONNECTED_SITE
... (snip snip) ...
Feb 12 07:57:26 titan NetworkManager[1246]: <info>  [1644623846.1872] manager: NetworkManager state is now CONNECTED_GLOBAL
(you don’t necessarily need sudo to query the status of a systemd service, but you could prefix that with sudo - as in “sudo systemctl status NetworkManager”)
What you’re looking for is “loaded” and “active (running)” - or any errors below those lines. If it shows something else - e.g. error, inactive, dead - then maybe try restarting it (you will need sudo) :
sudo systemctl restart NetworkManager
then check it again :
Or even maybe :
sudo systemctl stop NetworkManager
Wait 20-30 seconds, then start it again :
systemctl start NetworkManager
But - if that still doesn’t work - not sure how I can help - sorry
 I can only make certain assumptions - e.g. your ethernet switch is also your internet / wifi router / modem device, and it has a DHCP server running and providing IP addresses via ethernet.
My ethernet link is a bit more complex, at my desk in my home office, I have a 24 port switch, that’s cabled to a 500 Mbit Ethernet over Power (Powerline) device, my WiFi modem/router is patched to another Powerline device in the kitchen - whenever anything goes wrong, power outage, one Powerline device goes offline, ethernet still works “isolated” (ethernet devices in my office can still talk to one another, but not beyond my switch), i.e. my DHCP scope’s leases are so long, devices keep their IP addresses for days before asking for a new lease, if there’s an issue with Powerline devices, I usually just pull them out of the wall and plug them back in.
Note : I just saw your update. Looks like it’s running, but you could check for any errors with (sometimes the “debug” info at the bottom of the output has clues to which files to check - not that I’ve ever had to - NetworkManager on Ubuntu seems mostly plug and play - but not always so on Debian):
as my process tree looks much like yours :
ps -ef |grep -i network        130 ↔
root        1246       1  0 Feb07 ?        00:03:00 /usr/sbin/NetworkManager --no-daemon
root        1256       1  0 Feb07 ?        00:00:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
Also show us the output of
ip a
or maybe
sudo /sbin/ifconfig -a
– and furthermore –
To find out some DHCP info - something like :
╭─x@titan ~
╰─➀  sudo ls -al /var/lib/NetworkManager
total 64
drwx------  2 root root 4096 Feb 12 08:31 .
drwxr-xr-x 87 root root 4096 Feb 11 17:38 ..
-rw-r--r--  1 root root 1212 Feb 21  2021 dhclient-2b36729a-a43d-3d8e-a353-4763e90a0212-enp39s0.lease
-rw-r--r--  1 root root   69 Feb 21  2021 dhclient6-2b36729a-a43d-3d8e-a353-4763e90a0212-enp39s0.lease
-rw-r--r--  1 root root 2324 Feb 21  2021 dhclient-enp39s0.conf
-rw-r--r--  1 root root   57 Feb 11 03:40 internal-2b36729a-a43d-3d8e-a353-4763e90a0212-enp39s0.lease
-rw-r--r--  1 root root   55 Dec  5 18:55 internal-30729d94-0b0d-3e2d-8f53-8f6137b02626-enx1a5589a26942.lease
-rw-r--r--  1 root root   57 Oct 21 21:43 internal-31934c8a-c65b-3c30-95e8-e699c0a44721-eth0.lease
-rw-r--r--  1 root root   57 Feb  2 19:46 internal-50656978-691b-4c28-a80b-117c88314036-wlp41s0.lease
-rw-r--r--  1 root root   55 Sep 28 20:20 internal-690207c9-2352-3a1d-9b68-68300d6f06fd-enx1a5589a26942.lease
-rw-r--r--  1 root root   57 Oct 24 12:20 internal-b1ca5a16-deec-3a8f-b210-834dd65d1ad4-eth0.lease
-rw-r--r--  1 root root  939 Feb 21  2021 NetworkManager-intern.conf
-rw-r--r--  1 root root   69 Feb  7 15:39 NetworkManager.state
-rw-------  1 root root   32 Feb 21  2021 secret_key
-rw-r--r--  1 root root   70 Feb  7 15:39 seen-bssids
-rw-r--r--  1 root root  868 Feb 12 08:31 timestamps
Above - the file I’m looking for is *.lease file with my NIC device name “enp39s0”, but the slightly longer version of this file is for IPV6 “dhclient6” - I’m only interested in IPV4 “dhclient” - so :
╭─x@titan ~
╰─➀  sudo cat /var/lib/NetworkManager/dhclient-2b36729a-a43d-3d8e-a353-4763e90a0212-enp39s0.lease
lease {
  interface "enp39s0";
  fixed-address x.x.x.x;
  option subnet-mask x.x.x.x;
  option routers x.x.x.x;
  option dhcp-lease-time 604800;
  option dhcp-message-type 5;
  option domain-name-servers 8.8.8.8,8.8.4.4;
  option dhcp-server-identifier x.x.x.x;
  option domain-name "LOCAL";
  renew 3 2021/02/24 05:43:19;
  rebind 6 2021/02/27 06:22:19;
  expire 0 2021/02/28 03:22:19;
lease {
  renew 2 2021/02/23 22:11:18;
  rebind 6 2021/02/27 07:56:08;
  expire 0 2021/02/28 04:56:08;
lease {
  renew 3 2021/02/24 04:02:12;
  rebind 6 2021/02/27 07:58:09;
  expire 0 2021/02/28 04:58:09;
(note - I’ve “redacted” my site specific addresses with x.x.x.x)
Active: active (running) since Friday 2022-02-11 10:52:05 CST; 7hr ago
Main PID: 79364
Tasks: 3 (limit: 3573)
Memory: 8.4M
CGroup: /system.slice/NetworkManager.service ->79364 /usr/sbin/NetworkManger --no-daemon
 Ill run the other commands and post back. Working tonight.
trekjunky@Enterprise:~$ aptin wicked
[sudo] password for trekjunky:
Sorry, try again.
Reading package lists
 Done
Building dependency tree
Reading state information
 Done
E: Unable to locate package wicked
So it looks like you only have NetworkManager, but it is dead or inactive, or poorly configured
Follow what Daniel suggests.
@TrekJunky
So they have removed it, just like Devuan.
Must be a reason for scrapping it. Maybe the project folded
NetworkManager seems to have taken over in most distros. It is not easy to configure, in my opinion
@nevj
To me this looks like it is running :
It’s “loaded”, and “enabled”, its Active state is : “active (running)”
But I’d need to see all the debug / diag stuff at the bottom of the output - e.g. in my case :
     Memory: 13.3M
Feb 12 06:56:14 titan NetworkManager[1246]: <info>  [1644620174.0398] manager: NetworkManager state is now CONNECTED_SITE
Feb 12 06:56:15 titan NetworkManager[1246]: <info>  [1644620175.5411] manager: NetworkManager state is now CONNECTED_GLOBAL
Feb 12 07:06:35 titan NetworkManager[1246]: <info>  [1644620795.0400] manager: NetworkManager state is now CONNECTED_SITE
Feb 12 07:06:35 titan NetworkManager[1246]: <info>  [1644620795.5163] manager: NetworkManager state is now CONNECTED_GLOBAL
Feb 12 07:56:55 titan NetworkManager[1246]: <info>  [1644623815.0402] manager: NetworkManager state is now CONNECTED_SITE
Feb 12 07:57:03 titan NetworkManager[1246]: <info>  [1644623823.6364] manager: NetworkManager state is now CONNECTED_GLOBAL
Feb 12 07:57:18 titan NetworkManager[1246]: <info>  [1644623838.0401] manager: NetworkManager state is now CONNECTED_SITE
Feb 12 09:02:44 titan NetworkManager[1246]: <info>  [1644627764.0398] manager: NetworkManager state is now CONNECTED_SITE
Feb 12 09:02:59 titan NetworkManager[1246]: <info>  [1644627779.5621] manager: NetworkManager state is now CONNECTED_GLOBAL
And any DHCP info - per my earlier post.
@wadesmart
@daniel.m.tripp
I wonder is the ethernet connector not turned to connected in the panel icon?
There’s also the output of nmcli, or even “nmcli device show”
 If you’re going to paste the output - could you format it as “code” - i.e. select the text you pasted and hit the “</>” button in the forum toolbar (next to " and left of the “Upload” button) - it makes our job easier to read your output if character spacing and indentation is “preserved”
╭─x@titan ~
╰─➀  nmcli
enp39s0: connected to Wired connection 1
        "Realtek RTL8111/8168/8411"
        ethernet (r8169), 2C:F0:5D:74:48:B8, hw, mtu 1500
        ip4 default, ip6 default
        inet4 x.x.x.x/24
        route4 0.0.0.0/0
        route4 x.x.x.0/24
        route4 169.254.0.0/16
        inet6 fe80::dd6b:44d4:76e9:4a2e/64
        route6 fe80::/64
        route6 ::/0
wlp41s0: unavailable
        "Intel 6 AX200"
        wifi (iwlwifi), 68:54:5A:D3:53:74, sw disabled, hw, mtu 1500
lo: unmanaged
        "lo"
        loopback (unknown), 00:00:00:00:00:00, sw, mtu 65536
gpd0: unmanaged
        "gpd0"
        tun, sw, mtu 1500
DNS configuration:
        servers: x.x.x.x
        interface: enp39s0
Use "nmcli device show" to get complete information about known devices and
"nmcli connection show" to get an overview on active connection profiles.
Consult nmcli(1) and nmcli-examples(7) manual pages for complete usage details.
Note : wlp41s0 is unavailabe 'cause I disabled WiFi in the top panel doohicky widget thingie on the right, “Wi-Fi Off” :
Try wicd
We are both spelling it wrong
Debian and Devuan have removed wicd because it depends on python2. When the python3 version of wicd is available, it might reappear.
So the basic install misconfigures on install?
Hi Wade,
I missed this comment way back
Does it really fail to connect the wired interface with the lower panel button?
It is confusing
When it is disconnected, the button says connect
When it is connected, the button says disconnect
Stupid isnt it.
Now if that is the case, I wonder if the driver for the ethernet interface does not load when you boot?
Can check it easily - use dmesg
sudo dmesg | more
and scroll thru all the boot sequence until you find name of ethernet interface. What does it say there? Does it load a driver?
Yes - never connected when it it did that.
See my other reply.
If the interface does not connect NetworkManager will not configure it.
NetworkManager is dynamic, it will configure at any time ( because it is a daemon) but the interface has to be connected. It configures at boot too, but if you add something while Linux is running NetworkManager hops in and configures the new item.
It can be very confusing
Right, so something is not enabling the interface, before it gets to NetworkManager.
Can you go ahead and investigate if the driver is there using
sudo dmesg | more
Sorry for slow reply. We had our covid booster yesterday - some reaction - sleeping it off
@daniel.m.tripp
Can you think of anything other than a driver missing that would cause the lower panel button not to connect to an ethernet interface?
No idea mate
 curious to see if nmcli works, and what the output is
 I’ve no idea what wicd is, never used it
Good job on getting your booster @nevj mate! I got AZ first two shots (got crook for a couple days after first one), but Pfizer for my booster, all I got was a sore arm for a couple days.
@daniel.m.tripp
Yeah, we had same, 2 x AZ, and now Phizer. Am sleeping it off today.
Wife had bad reaction to second AZ - rash, suspected clots, the works.
She is better than me this time with Phizer.
Will prompt Wade to do the nmcli
@wadesmart
Can you also do the
nmcli
that Daniel suggested please?
