This was one of the most charming of the alternatives. Check out:
It can also be installed using SNAP.
Howard @easyt50 should find this one quite nice.
Here is a PDF book with everything you need for the Terminal, it helped me out link below
http://cc.iiti.ac.in/docs/linuxcommands.pdf
Or there is this one for beginners
Thanks for sharing both of these ![]()
tldr was the other one I was trying to think ofâŚ
will come in handy next time Iâm using âddâ to write a USB boot stick, or an SDCARD for an SBC - Iâm always forgetting the ânice to haveâ arguments like progress and sync (and furiously searching through my command history to find things like âconv=syncâ)âŚ
thanks for sharing!
I really wish there was a way I could have all my shell utilities and settings syncâd across devices⌠as it is - I keep my main ~/bin/ shell scripts in Resilio Sync⌠and my ~/.ssh/config (using symlinks)⌠but I need more ![]()
at first i wasnât sure about watching a whole 7+ hour video (iâve still only made my way to just over 2), but there is some good info there. from the basics of an ubuntu install to plenty of command line examples and explanations. if you click âshow moreâ beneath the name of the person who posted the video, there is a list of time stamps for different sections. âLinux command line essentialsâ starts just after the 1 hour and 23 minute mark (1:23:09 to be exact).
i had never seen sudo !! (repeat the previous command with sudo) before. i have used it a couple of times since. definitely quicker than retyping the whole thing ![]()
Another option, with the same number of keystrokes (seven): hit right-arrow up-arrow home-key to recall the previous command and move to its beginning, then type sudo and a space.
Here is another superb introduction. I hope Howard @easyt50 gets a chance to appreciate the clear prose!
is this determined by the specific terminal? in mine (terminology) the up arrow gives me the previous command.
Oops. I meant up-arrow, not right-arrow. Thanks!
just wanted to make sure i wasnât missing something ![]()
one of the key combinations that i find useful specifically in dealing with already used commands is ctrl + r (reverse-i-search). i think i first found it while i was dealing with conky -c /path/to/conf/file and wanted a way to run it frequently without having to type it all over each time. later i learned how to assign an alias, but ctrl + r still comes in handy when trying to remember a command i might not use very often.
Thanks, I got my copy from Amazon.
