I made a mistake: before installation I made the partition logical and I can’t access it; a mint sw called ‘logical volume management’ displays a button to remove logical partition+physical volume - is it safe to remove both with that sw? Either way, what should I do to recover my data?
In such a situation, I would advise you to just restore the backup you created before doing such a critical task.
You have such a subtle wrist
