Good morning!
I did a clean install with ulyssa today. In mnt there are no devices listed although all harddrives have been mounted and are accessible, anyone got any ideas?
Thank you!
Good morning!
Thank you!
Did you look in /media
Are your hard drives built in or are they plugged in via USB?
You would also probably not find the drive your system is installed on in mnt
but rather in /dev/sdXY
where X
ā {a,b,c,ā¦} and Y
ā {1,2,3,ā¦}. However: These directories are not meant to be accessed directly by the user.
What @Akito said : /mnt is generally used (e.g. in online examples) to manually mount something
sudo mount /dev/sdb1 /mnt
or
sudo mount /dev/sdb1 /some/arbitrary-folder-that-exists/anywhere-on-my-root-fs
in fact - with manually mounting - you could in theory mounting anything, nearly anywhere - e.g. you can mount a Samba share in mountpoint thatās actually a subfolder of an NFS mountpoint - but please donāt remind me of such nightmare scenarios
Did just now! There are 2 from 6 devices listed. My problem is with programs like Clementine⦠They do not offer āother locationsā when data needs to be imported. My way round it was to go to mnt and click on the drive, however that was just my solution and I am sure there are better ways. I also have the same problem when I need to import photosā¦āother locationsā are not offered. Due to the size of my music collection and photos having them in home is not a viable concept
Lol!!! That I am not going to do!!!
They are all built in drives⦠I wrote an answer to Akito to show what me real problem isā¦
Hugsie,
Ute
Possibly Iām telling you what you already know. When I plug in a new disk, I do the following:
sudo blkid
blkid stands for block device identifier and can be anything from a hard disk, a DVD to a connected pen-drive.
and I get a list like this:
/dev/sda1: UUID="abc" UUID_SUB="def" TYPE="btrfs" PARTUUID="ghi" /dev/sda2: UUID="jkl" TYPE="swap" PARTUUID="mno" /dev/sdb1: LABEL="hdd" UUID="pqr" TYPE="ext4" PARTUUID="stu"
If I now want access to the second hard disk I open the file /etc/fstab
e.g. with:
sudo nano /etc/fstab
and add a line like:
UUID=pqr /home/mina/data ext4 defaults,nofail 0 1
I then create an empty directory with
mkdir data
and execute
sudo mount -a
The a option stands for all.
Now, if you reboot your computer, it should be mounted in the right place, right from the beginning. The nofail
option in the /etc/fstab
file is especially useful if it is a removable device. With this option missing and the device not plugged in, your system will fail to boot.
BTW: I didnāt know the music player Clementine until you just mentioned it. Itās very nice, and I definitely see all my mounted disks, even those mounted from my other computer.
