Hello Friends
I have the following MacBook Pro (because in the bottom appears the “Model No.: A1278” content):
My city had a flood and the laptop was unharmed but sadly the MagSafe was within water and mud for practically 1.5 days
The MagSafe has the “Model No.: A1344” content
I need buy a new one as not original because it is old hardware (in other words equivalent/compatible)
I found these two ones in Amazon (where for each one appears both codes: A1278 and A1344)
- Mac Book Pro Charger,60W Power Adapter L-Tip Magnetic Connector Charger and Compatible with Pro 13 Inch Before Mid 2012,Fast Charger for Old Mac Book Pro manufactured by E-POWIND
- Mac Book Pro Charger - 60W L-Tip Power Adapter,Compatible with Adapter for Mac Pro 13 inch Before Mid 2012(Mac Book 2009-2010) manufactured by SorsnA
I need your orientation because the manufacturers are not known by my side. Therefore
- Which one is better over the other and why?
- Do you have other recommendation? I mean other manufacturer (if yes, pls share the amazon link)
Thanks in advance
