Yes indeed, it can be very helpful. I have sent part of my Linux log to AI to be scan and give me feedback.
I found and use
Mainly as our president when writing to me uses AI instead of thinking
But who decides good design if not the developer? Limiting the number of error messages by only reporting those of some level of severity will only end up as too few for some users while there will never be few enough for others.
create a system of defining
If you ask me, the better solution would be to
Agreed, but who is to define which errors to report, or how an error message should be organized or phrased - what constitutes ambiguous or meaningless - if not the developer?
Perhaps a better solution would be for the GNU/Linux community of developers, or some global organization such as the Linux Foundation, to define clearly defined severity levels for error reporting alongside a log viewer that can limit its output based on the user requested level or higher.
If anyone reading this thread is a developer, I’m sure that the rest of us would appreciate their authoritative response.
@callpaul.eu, Thank you for the GPTZero link. I’ve added the Firefox extension, so I’m hoping that it will help me better detect AI-generated posts, and perhaps help me with complex posts.
Linux has some terrible error messages. If I forget to mount a partition I am trying to copy a file to I get something like “permission denied”. The partition is not mounted. Also I was getting a error message displayed on the screen, and I didn’t know where it was from. @Rosika showed me a trick to ID the error message to see where it came from. It was coming from my cloud storage.
GPTZero, I have found is not really as accurate as they claim. My wife use to use it (teaches English) and said it gave too many false positives. - Just my two cents worth.
Do you have other suggestion that are better and free ?
It was the first one I found and appeared to work and in french as well as english which was part of my need
Not really- for me most just follow a pattern. Like recognition of something then validation next insight then the take away. The responses seem very canned to me.
Here is an AI explaining the false positives
The logic is that AI writes by picking high-probability words, so text the model finds very predictable is probably text a model could have written. The flaw is that humans also write predictable sentences all the time, especially simple, clear, or common phrasing. “The meeting was moved to Tuesday because of the holiday” is completely human, but a model would find every word unsurprising.
So “predictable” here doesn’t mean boring or obvious to a reader. It means statistically likely from the model’s point of view, which is why ordinary, well-written human sentences can get caught.
Remember Guru from Amica? Or Syntax error?
When I have issues with program I run it from terminal and I can see “live” what happens before the program dies. It is really helpful
Yes it is the developer or programmers fault.
We need an entirely different error and logging system.
We need programmers who can write human-readable sentences
Start again from scratch … dropping every event onto an error blog is not good enough.
I was running the command from the terminal. It was a cp command to copy a file form one disk to another as backup. I had ran it many times so it really confused me when I got the message;
cp: cannot create directory '/media/easyt/Time': Permission denied
The partition was not there, I had forgotten to mount it. But with an error of permission denied threw me off track. The disk was not there so the error message had noting to do with permissions.
Exactly the sort of thing I am talking about.
I do believe it would have been possible for the program to produce a message saying ‘cant find /media/easyt’ and not mentioning ‘permissions’
I agree. That’s why I think some sort of standard needs to be developed and published - maybe similar to the ISO standards, but targeted to GNU/Linux
Thank you for your input. Since I never rely solely on the input of AI alone, hopefully I’ll uncover the times when I get a false positive, time will tell.
[quote=“Neville Jackson, post:50, topic:16363, username:nevj”]
[/quote]That’s why I suggest some sort of well defined standard that developers can follow, maybe something modeled after the ISO standards.
