The checksum I got was 0d56669ba4388d8b68c18221827f1c89ceaa49091437eb04f78ecfd1ef45b436 *Win10_21H1_EnglishInternational_x64.iso.
This is the file from the Microsoft site.
I just downloaded an ISO from Microsloth (100% legit*) and installed in VirtualBox (running on Ubuntu 20.04) and had no problems whatsoever, apart from it slowing my Linux to a crawl (I have 16 GB RAM and 8 cores in Ubuntu - I gave the VM 8 GB of RAM and 4 cores)…
I’d forgotten how much I hate (that’s putting it mildly) installing Windows…
Apparently “We’re getting everything ready for you…” and “This might take several minutes…” yeah right… and then the old “Leave everything to us.”…
I don’t have an activation code, yet… I don’t care… probably won’t use it… I’ve got various 2012 / 2016 / 2019 Windows servers I can RDP to, or Citrix…
Got the ISO from here :
https://www.microsoft.com/en-au/software-download/windows10ISO
That differs from what I read in the table…
Judging by the length of that sum I’d guess you used sha256?
I just ran both md5 and sha256 and got a very different checksum (and the filename is the same as quoted by you) than you’ve quoted :
╭─x@titan ~/BNZ/ISO/Windows
╰─➤ md5sum Win10_21H1_EnglishInternational_x64.iso
b51e1111832c42b5917947d8ca1d611b Win10_21H1_EnglishInternational_x64.iso
╰─➤ sha256sum Win10_21H1_EnglishInternational_x64.iso
cb8731a17350b2f61ad1c059fc16fd6348530c25e43f631f2691768f767f75c3 Win10_21H1_EnglishInternational_x64.iso
╰─➤ ls -al Win10_21H1_EnglishInternational_x64.iso
-rwxrwxr-x 1 x family 5832765440 Oct 1 14:18 Win10_21H1_EnglishInternational_x64.iso
Now - I can’t get a checksum from Microsoft so I can’t verify the “source” - but - I was successfully able to install Windows 10 from that ISO image file in VirtualBox (desktop version running on Ubuntu 20.04).
Note : I also ran sha512sum (overkill) on it - and that’s still very different from the result you got.
Back in the olden days, I used to sometimes use plain vanilla “UNIX” cksum to compare two files - but it can be used in this case, although it’s nowhere near as rigorous as md5 or sha :
╰─➤ cksum Win10_21H1_EnglishInternational_x64.iso
3611003494 5832765440 Win10_21H1_EnglishInternational_x64.iso
so you can, so you can, I stand (actually, I’m sitting down) corrected
Microsoft :
CB8731A17350B2F61AD1C059FC16FD6348530C25E43F631F2691768F767F75C3
Me (sha256) :
And NOT a SINGLE one starts with 0d5… per @asharpham original post… So - NONE of them match :
So to me - it looks like you got yourself a dud, mate… Try again?
Maybe use a resumable download manager, to be sure, to be sure? I find Brave’s default downloader does a reasonable job as “download manager” - but if it’s something I really want/need - I usually use wget as my download manager…
I’ll download the same file again and let you know the result.
By the way, I’m downloading from Download Windows 10 Disc Image (ISO File).
Interestingly, the ISO file I just downloaded is 5.8Gb whereas the ‘same file’ I downloaded last time was 4.3Gb. The only difference is the new file came from ‘en-gb’ instead of ‘en-au’.
A friend finally got it working for me. It appears the missing step was to create another optical drive. I was selecting the existing (physical) CD drive. He also provided a different ISO file.
So yeah - you got a dud file…
Setting VirtualBox to use a downloaded ISO file aint rocket science, and, is exactly the same process as on a Windows machine or a Mac running VirtualBox…
Weird. I got it from the Microsoft Australia site.
Thought I would share what I had to do to get W10 Home Edition to install in VirtualBox.
