Python question
Inside myProjects/jupyter-env/venv there is a file expt1.ipynb. It contains config info and some strange binary-like coding
 "cells": [
   "cell_type": "code",
   "execution_count": 3,
   "id": "77c430a4-007b-42ec-b364-fcc23d6bf479",
   "metadata": {
    "scrolled": true
   "outputs": [
     "ename": "FileNotFoundError",
     "evalue": "[Errno 2] No such file or directory: 'expt1.csv'",
     "output_type": "error",
     "traceback": [
      "\u001b[31m---------------------------------------------------------------------------\u001b[39m",
      "\u001b[31mFileNotFoundError\u001b[39m                         Traceback (most recent call last)",
      "\u001b[36mCell\u001b[39m\u001b[36m \u001b[39m\u001b[32mIn[3]\u001b[39m\u001b[32m, line 2\u001b[39m\n\u001b[32m      1\u001b[39m \u001b[38;5;28;01mimport\u001b[39;00m\u001b[38;5;250m \u001b[39m\u001b[34;01mpandas\u001b[39;00m\u001b[38;5;250m \u001b[39m\u001b[38;5;28;01mas\u001b[39;00m\u001b[38;5;250m \u001b[39m\u001b[34;01mpd\u001b[39;00m\n\u001b[32m----> \u001b[39m\u001b[32m2\u001b[39m df = \u001b[43mpd\u001b[49m\u001b[43m.\u001b[49m\u001b[43mread_csv\u001b[49m\u001b[43m(\u001b[49m\u001b[33;43m'\u001b[39;49m\u001b[33;43mexpt1.csv\u001b[39;49m\u001b[33;43m'\u001b[39;49m\u001b[43m)\u001b[49m\n\u001b[32m      4\u001b[39m \u001b[38;5;28;01mimport\u001b[39;00m\u001b[38;5;250m \u001b[39m\u001b[34;01mnumpy\u001
When I start jupyter
trinity:[nevj]:~/Projects/jupyter-env$ source venv/bin/activate
(venv) trinity:[nevj]:~/Projects/jupyter-env$ ls
expt1anal.py  Untitled1.ipynb  Untitled2.ipynb  untitled.py
expt1.csv     untitled1.py     Untitled.ipynb   venv
(venv) trinity:[nevj]:~/Projects/jupyter-env$ jupyter lab
I can do File → Open → Recents → expt1.ipynb
and it brings back my Notebook workspace … ie all the cells.
In the Jupyter tab, there seems to be an option to export
I tries Restructured Text and it made a file expt1.rst in the ~/Downloads directory… Why there?
It contains the code from my first cell, plus heaps of garbage.
If I choose Executable Script I get expt1.py in ~/Downloads, and it contains code only.
So it looks like one can recover code fron Jupyter.
So youĀ“re asking how to take the code and documents you’ve created in JupyterLab and save them as standard text files - such as Python scripts or Markdown files - outside the notebook format, I guess.
Since I haven“t done any of this yet, let“s see what perplexity has to say about it:
Exporting from JupyterLab
JupyterLab provides built-in export options for notebooks:
  • To export your notebook as a Python script (.py), Markdown (.md), or other formats:
    1. Open your notebook in JupyterLab.
    2. Go to the File menu.
    3. Select Export Notebook As….
    4. Choose your desired format, such as Export to Executable Script (for a .py file) or Export to Markdown (for a .md file)
This will create a standard text file containing your code or documentation, which you can then download, edit, or use elsewhere.
Command-Line Option
Alternatively, you can use the command line to export notebooks::
jupyter nbconvert my_notebook.ipynb --to script
This will generate a my_notebook.py file with all the code from your notebook
Export Formats
JupyterLab supports exporting to several formats, including:
Python script (.py)
Markdown (.md)
HTML (.html)
LaTeX (.tex)
PDF (may require extra setup)
ReStructuredText (.rst)
Summary Table
Export Option File Type Use Case
Executable Script .py Standard Python code file
Markdown .md Documentation, sharing notes
HTML .html Web viewing/sharing
PDF .pdf Printable, shareable document
In short:
Use the File > Export Notebook As… menu in JupyterLab to save your code and documents as normal text files like .py or .md. This makes it easy to use your work outside of JupyterLab
As always with AI the results have to be taken with a grain of salt, but the output looks pretty sensible so far. :blush:
I decided to go back to the manual venv environment, and try to access the file there
trinity:[nevj]:~/Projects/collagen$ source venv/bin/activate
(venv) trinity:[nevj]:~/Projects/collagen$ python
Python 3.13.3 (main, Apr  9 2025, 17:13:31) [GCC 14.2.1 20250207] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import pandas as pd
>>> df = pd.read_csv('expt1.csv')
>>> df
            Farm       Grade  Sheep  Field  ...       Red     Green      Blue  Count
0       Glensloy      smooth   3457      1  ...  0.734539  0.304495  0.263945    732
Yes, it works there
I tried the collagenuv environment too,
trinity:[nevj]:~/Projects/collagenuv$ source .venv/bin/activate
(collagenuv) trinity:[nevj]:~/Projects/collagenuv$ python
>>> import pandas as pd
>>> df
(collagenuv) trinity:[nevj]:~/Projects/collagenuv$ deactivate
So, it is not a virtual environment problem, it has to be a jupyter lab problem
So try jupyter again
Now I am goint to run the following in a Notebook cell
OK, that is the problem…jupyter lab Notebook works in the directory
/home/nevj/Projects/jupyter-env/venv
whereas python REPL works in the directory I start it in.
So, I have to either
  • change the filename to ../expt1.csv in the python script, or
  • move the file into venv or make a link… I dont like that, or
  • find some way to change the cwd in jupyter
    I think the last… any suggestions?
Outside of jupyter the pwd is
(venv) trinity:[nevj]:~/Projects/jupyter-env$ pwd
but if I start jupyter in that directory its cwd becomes
Confusing?
I have a solution
Then it can read the file.
It remains to be seen if that affects other things in jupyter lab
Update:
I found this
" People also ask
How to change CWD in Jupyter notebook?
Part of a video titled Set working directory in jupyter notebook using Python ... - YouTube
2:18
3:24
So we also provide the same convention. Okay in all the places. So that it can easily locate myMore
[image]
https://www.youtube.com Ā· The Data Empower
Set working directory in jupyter notebook using Python … - YouTube
How do I change the default directory in JupyterLab?
How to Change Jupyter Notebook Default Folder
  1. Open the terminal or command prompt on your computer.
  2. Type jupyter notebook --generate-config and press Enter. …
  3. Type jupyter --config-dir and press Enter. …
  4. Navigate to the configuration directory using your file explorer.
More items…
27 Dec 2023 "
I dont know whether the default directory is the one you see with os.getcwd()
The there is this
https://medium.com/@royce963/setting-up-jupyterlab-and-a-virtual-environment-c79002e0e5f7
which suggests I should be using ipykernel with jupyter lab ?
And some constructive criticism here
https://orell-garten.medium.com/using-virtual-environments-with-jupyter-lab-is-broken-bbbd0a1867bd
O.K., let“s consider what peplexity suggests. As we“ve already taken this path we might as well follow it a bit further. :wink:
This way I hopefully can learn something new, too.
Your friend is correct that JupyterLab and the Python REPL can have different working directories, which affects how relative file paths are resolved. Here are the main ways to address this in JupyterLab:
Options for Changing or Handling the Working Directory
  • Change the working directory in your notebook code:
    You can add this at the top of your notebook to set the working directory to where your data file is:
import os
os.chdir('/path/to/your/project')
Replace ā€˜/path/to/your/project’ with the directory containing expt1.csv. This is a straightforward solution and works immediately for that notebook session
  • Start JupyterLab from the desired directory:
    Before launching JupyterLab, open your terminal, cd to the directory where your files are, and then run:
    jupyter lab
    JupyterLab will use this as its root directory, and relative paths will work as expected
  • Edit the Jupyter configuration (advanced):
    You can set a default startup directory by editing the Jupyter configuration file.
  1. Generate the config file if you haven’t:
  2. Open ~/.jupyter/jupyter_notebook_config.py and find the line:
    #c.NotebookApp.notebook_dir = ''
    Remove the # and set it to your desired directory:
    c.NotebookApp.notebook_dir = '/home/nevj/Projects/jupyter-env'
  3. Save and restart JupyterLab
Summary Table
Method What to Do When to Use
Change cwd in notebook code os.chdir('/path/to/dir') For quick, per-notebook changes
Start JupyterLab from project dir cd /path/to/dir && jupyter lab For session-wide consistency
Edit Jupyter config file Set c.NotebookApp.notebook_dir in config For permanent, default directory
Recommendation:
For most users, either starting JupyterLab from the desired directory or adding os.chdir() at the top of your notebook are the easiest and safest solutions
Personally IĀ“d refrain from ā€œEditing the Jupyter configuration (advanced)ā€ and choose either option1 or 2.
That“d be my personal preference, of course.
Well, AI got that wrong.
That is what anyone would expect, but I just demonstrated that jupyterlab chose venv as the cwd even though I started it in the parent directory.
Can you perhaps try your jupyterlab and see if it does the same? I may be doing something stupid. No hurry, I can shelve this.
Did you see the update on last reply?
No, it seems I missed it.
I“ll have to read it through first.
I think I’d lean towards doing the cd in the notebook. ā€œcd ~/Projects/ā€.
If you were working with a team of people on a project, that might not work very well. But, then again, it might work perfectly. Everyone would go to the same location for the project.
One of the things I don’t like about notebooks, and I don’t really use them, is that you can execute cells out of order. So, if you didn’t execute top to bottom, you won’t be in the correct directory.
Yes. I think that pushes you towards an object oriented rather than functional code. You still need a main routine that has to be first.
The newer Marimo notebook I mentioned before DOES execute top to bottom. It sure seems like that makes much more sense and would also be more reproducible.
It does some caching to avoid ā€œexpensiveā€ function calls.
I think that is worth a look.
Jupyter does not execute all cells… you choose the cell to run, but you can choose in any order.
It seems to me Notebooks are good for developing little snippets of code , or a couple of functions. I cant imagine it working for a large program.
I don’t know that you need to use a notebook at all. When you were working with Julia it seemed your workflow was more suited to using whatever your preferred editor is and running the resulting program at a command prompt. I like working that way too, though I do like to use VS Code for the debugger.
Right. I feel more in control with the python REPL and vi. Happy with UV though.
Python REPL is different to Julia. In Julia REPL I can copy in a slab of code and it runs.
In Python REPL it seems to only accept one line of code at time. … You may know a way around that.
THAT IS WRONG… it does accept a copied slab of code
>>> import pandas as pd
... df = pd.read_csv('expt1.csv')
... import numpy as np
... #import matplotlib.pyplot as plt
... import scipy.stats as stats
... import statsmodels as sm
... import statsmodels.formula.api as smf
... # model1 = ols('Area ~ C(Farm) + C(Grade)', df).fit()
... # model1 = smf.ols('Area ~ C(Farm) + C(Grade)', df).fit()
... # model1 fit
... from statsmodels.formula.api import ols
... from statsmodels.stats.anova import anova_lm
... model1 = ols('Area ~ C(Farm) + C(Grade)', df).fit()
... model1.summary()
... anova_lm(model1)
... # model2 fit
... model2 = ols('Area ~ C(Farm) + C(Grade) + C(Farm):C(Grade)', df).fit()
... model2.summary()
... anova_lm(model2)
                        df        sum_sq  ...            F        PR(>F)
C(Farm)                1.0  1.429054e+10  ...  2028.908896  0.000000e+00
C(Grade)               1.0  3.777585e+08  ...    53.632501  2.431477e-13
C(Farm):C(Grade)       1.0  2.928109e+09  ...   415.720047  2.930235e-92
Residual          127235.0  8.961750e+11  ...          NaN           NaN
[4 rows x 5 columns]
I think those dots confused me… and it only prints the last line of output which in the above is from anova_lm(model2)… you dont get to see the output from model2.summary() or any previous lines.
I will get used to that. It actually helps because all I want to do is run the code down to the last working line, so I can debug the next step. The intermediate output is superfluous.
It has to be working code… an error in the middle will hang
Jupyter was more of a curiosity exercise… why does everyone use Notebook for R and Julia? I dont have the answer yet, but I at least know what a Notebook is.
Back in collagenuv environment.
Have already done uv venv
My setup does
uv python install
uv pip install pandas
uv pip install scipy
uv pip install statsmodels
I have discovered that I can do the above before or after I do source .venv/bin/activate… it does not matter , uv pip still installs them in .venv/lib/....
I can run a script with uv run expt1anal.py either before or after doing source .venv/bin/activate… it still runs in the collagenuv environment.
to use the python REPL in the collagenuv environment, I have to do
python
So UV acts like an automatic activate
I found the same thing. I thought I was crazy at first. It says right there, ā€œsource .venv/bin/activateā€ to activate the virtual environment.
Did you look at using a comment section at the top of the script rather than a virtual environment? I guess if you’re using the REPL that wouldn’t work for you.
pdecker@dpd-u2404:~/python/zzz$ uv add --script nev.py pandas scipy statsmodels
Updated nev.py
pdecker@dpd-u2404:~/python/zzz$ cat nev.py
# /// script
# requires-python = ā€œ>=3.13ā€
# dependencies = [
# ā€œpandasā€,
# ā€œscipyā€,
# ā€œstatsmodelsā€,
import pandas
import scipy
import statsmodels
That way you can just run:
uv run nev.py
and it runs with no virtual environment needed. I use an alias py=’ uv run’ and that makes it:
py nev.py
I forgot about that
my script works with uv run scriptname.py without any comments and it works whether I have activated the venv or not.
as long as I am in the project directory.
I guess putting in the comments does all the setup installs… OK I should use uv add to add the dependencies to my script. Thanks.
I use REPL when writing and debugging , plus vi to build a script file. Then if I want to use the debugged progam to process data, I run the script directly.
You’ll need an activated virtual environment for that I believe. I just think it’s handy to use the ā€œuv addā€ feature. During development and debugging that wouldn’t work well.
Right.
If using UV, that is the only thing that requires me to activate.
BTW, what happened to.venv/bin/deactivate ?
Mine seems to have disappeared? I wonder has it been removed in an update?
It is the only way to terminate an activation.
I’m confused by that too. I just created a venv and I do see a few versions of activate (for different platforms) along with one deactivate.bat. That isn’t what is executed, but when I execute the deactivate command it does deactivate the venv. I tried which deactivate but that didn’t find anything. Yet it works. Son of a gun.
It seems to be a shell command …like cd… which cd finds nothing too
So it is only there when the venv shell is running and all it does is kill the shell.
Tricky.
@nevj I thought you might like this.
