Hi altogether,
I´m posting my question here in the hope that somebody may help me with a certain “problem”.
I already posted it on Lxqt-panel restarted (and xpad shut down) - Lubuntu Support - Lubuntu Discourse (the lubuntu-forum) but never received an answer.
I´m using Lubuntu 20.04 and until now it happened 3 times that lxqt-panel shut down and immediately after that restarted.
In each case xpad (“sticky note application for X”) also terminated its process.
So my guess is that the weird behaviour of lxqt-panel might have something to do with xpad…
Anyhow, I looked at the logs (using lnav) each time and I think it´s best to post them here in case they may help:
1.)
│Feb 10 17:59:12 rosika-10159 kernel: [ 217.370577] lxqt-panel[1293]: segfault at 8 ip 00007f4dce24dedc sp 00007ffe9049a730 error 4 in libQt5Widgets.so.5.12.8[7f4dce0af000+3c4000]
│Feb 10 17:59:12 rosika-10159 kernel: [ 217.370591] Code: c0 4d 85 ed 74 08 4c 89 ef e8 60 d0 e6 ff 48 8b 7b 48 4c 89 6b 50 48 89 43 48 48 85 ff 74 0b f0 83 2f 01 75 05 e8 e4 d0 e6 ff <49> 8b 45 08 48 89 98 c8 02 00 00 48 89 6b 08 48│
│Feb 10 17:59:12 rosika-10159 kernel: [ 217.948033] traps: xpad[1538] trap int3 ip:7f7ed35d90b5 sp:7ffc45f50e80 error:0 in libglib-2.0.so.0.6400.6[7f7ed359d000+84000] │
2.)
│Mar 26 13:35:05 rosika-10159 kernel: [ 307.450650] lxqt-panel[1391]: segfault at 8 ip 00007f2beb1a8edc sp 00007fff4c5c7f70 error 4 in libQt5Widgets.so.5.12.8[7f2beb00a000+3c4000] │
│Mar 26 13:35:05 rosika-10159 kernel: [ 307.450663] Code: c0 4d 85 ed 74 08 4c 89 ef e8 60 d0 e6 ff 48 8b 7b 48 4c 89 6b 50 48 89 43 48 48 85 ff 74 0b f0 83 2f 01 75 05 e8 e4 d0 e6 ff <49> 8b 45 08 48 89 98 c8 02 00 00 48 89 6b 08 48│
│Mar 26 13:35:08 rosika-10159 kernel: [ 311.231993] traps: xpad[1622] trap int3 ip:7fdcec67e295 sp:7ffe2f2b0230 error:0 in libglib-2.0.so.0.6400.6[7fdcec642000+84000] │
3.)
│Mar 30 18:47:57 rosika-10159 kernel: [20829.104808] lxqt-panel[1406]: segfault at 8 ip 00007f774c1deedc sp 00007ffe85c0ee30 error 4 in libQt5Widgets.so.5.12.8[7f774c040000+3c4000] │
│Mar 30 18:47:57 rosika-10159 kernel: [20829.104821] Code: c0 4d 85 ed 74 08 4c 89 ef e8 60 d0 e6 ff 48 8b 7b 48 4c 89 6b 50 48 89 43 48 48 85 ff 74 0b f0 83 2f 01 75 05 e8 e4 d0 e6 ff <49> 8b 45 08 48 89 98 c8 02 00 00 48 89 6b 08 48│
│Mar 30 18:47:59 rosika-10159 kernel: [20830.676874] traps: xpad[1620] trap int3 ip:7f354d213295 sp:7fff44367990 error:0 in libglib-2.0.so.0.6400.6[7f354d1d7000+84000]
Basically I´m at a loss as what to make of it.
Any help is welcome.
Thanks a lot in advance.
Mana greetings.
Rosika
