Recommendations for resources to research and buy machines for server purposes?
We are moving with phones, but not broadcasts
40 years ago, we moved to this house. We discovered that there’s an extinct volcano between us and the ridge where all the transmission towers are. (Portland has several extinct volcanos in the area, one of the bonuses for being in the Ring of Fire.) After fighting the antenna battle for a couple of years, we subscribed to the local cable network. We cut that cable several years ago when we discovered that we could benefit from streaming everything from the net. The Roku TV we bought is built to be a simple menu to help sort out and bring in internet services. We can even find Aussie Rules Football, although the game makes no sense to me.
Our TV uses Android. It is a pain to negotiate all the menus just to get a channel. Every channel has its own login setup, and the moment you setup a login you get swamped with emails. We avoid it.
Get Australian Rugby League … you might understand that , it is like American football.
I never understood ARL either until @daniel.m.tripp explained to me that it is in Gaelic.
No, rugby makes no sense. Can’t understand any of the penalties.
My school played rugby. I played every week and endured hours of reporting of results at weekly assembly. … but noone ever explained how to play or the rules.
It was sort of assumed that the school sport culture was everyones vital interest , while academia was only for the few bookworms.
Regional differences and assumptions. I had never heard of yogurt or bagels until I left the hinterlands for university in the big city.
Happy days, my first curry for lunch
My first grapefruit was at boot camp in the army.
It’s a broadcast standard VS the North American NTSC…
Both are essentially 4:3 ratio - but NTSC lower resolution…
Australia didn’t adopt colour TV broadcast until about 15 years after USA and Canada… Because we were so late to the party - we could adopt a better standard - I think most of Europe is also PAL - note : there are mutliple versions / implementations of PAL…
And they’re all irrelevant / redundant now anyway… e.g. ABC News ā€œFree To Airā€ is now HD - in a 16:9 ratio - and I think defaults to 1920x1080…
I’ve been looking at getting a more comfortable computer chair - one that can recline and fold away the armrests so it’s more like a sofa…
No it’s not in Gaelic - the two codes (Gaelic and Australian Rules) are not dissimilar - in both you can dribble the ball, there are goals and points (sometimes called ā€œbehindsā€) - but in Gaelic football, the ball is round, in AFL (not ARL) the ball is torpedo shaped like a rugby ā€œballā€ā€¦
I can follow a soccer match, AFL and/or Gaelic Football or rugby, and kinda figure out what’s going on - and they mostly have some decent continuation of play (less so in rugby) - the one code I don’t understand is ā€œAmerican Footballā€ or Gridiron - it’s annoying, they stop play every 5 minutes or less - it’s annoying - I don’t understand it - and there’s hardly ever continuous play… I guess if you grew up with it - it would be fine - but I grew up with a mix of Rugby, Soccer and Australian Rules…
Note : despite the designation ā€œGaelicā€ - it’s only played in Ireland (i.e. not Scotland), like Hurling… But it’s similar enough to AFL - there’ve been AFL matches with Aussies VS Irish, and Gaelic Football matches with Aussie AFL players VS Irish…
See my earlier post - Australia Rules is not dissimilar either, to an indigenous game called ā€œMarngrookā€ - and is possibly why most of the top tier Australian Rules players are of indigenous heritage…
Hello Friends
Huge thanks for the replies
Bill
Amazon is a good source. Newegg.com is another one. Be sure to search for refurbished machines–many used ones are perfectly usable.
Thanks for the advice of the bold part, it is acceptable if is for me, but for a potential customer is other history. For the italic part, according with Google it is not the same as ā€œrefurbishedā€. Therefore the latter is better. Of course new is much better than both but cost is other concern
I second that.. a machine a few years old will most likely run Linux without the driver issues that frequently occur with brand new hardware.
Good point, but in that case I prefer a ā€œrefurbished machineā€ because it was re-tested. Again it if is for my own use.
For a server , I would look at a desktop tower… they are cheaper than laptops and more maintainable.
Has sense, but now being curious: What would be better a PC Tower or Mini PC and Why?
Dan
Last time I bought a system to run as a server was on e-bay - refurbished Dell Optiplex SFF (it’s tiny but still has a half height PCIe GPU slot)… Check the reviews of the seller before committing…
Thanks for the bold and italic parts … pls could you consider in share the URL of your Dell if it is available? If not pls share the specs here
There’s actually very little difference between a Linux desktop and a Linux server… Is there even any?
At a first glance either 1 or 1.5GB less of RAM for the server against the Desktop. So the experience of the terminal is valuable for us…
(i.e. the binaries executed on user’s desktop UNIX machine, but display on remote X terminals - note: an X terminal is actually a ā€œdisplay serverā€).
Correct, GUI is used in the client machine if I want see some stats for example about Java I use JMX through VisualVM, for database interaction as admin is used DBeaver
Frost
Not sure where you’re based Manuel,
In south america
but I normally poke around Currys Business (if only to see what’s out there as they’re normally quite dear), manufacturer sites, GumTree/FB marketplace, CEX, and my local repair shop - they’ve always got loads of NAS kicking around. Seems like the second hand market around me is flooded with them.
The problem of the sale stores in my country is that the models are ā€œoldā€ and with the price being higher to pay the salesman commission and shipping costs and more … therefore is smart do the buy through the Web
I ended up building a mini ITX in the end as bang for buck went a lot further when I was looking.
Sounds great, could you consider in share the current specs?
Dan
Yeah - Nah! You can forget about it - they’re SO NOISY! They draw so much power!
I am assuming it is a big point in favor for a Mini PC
My NAS file server is 15 years old - still going HP N40L Microserver… dual-core AMD Turion 16 GB ECC RAM 16 TB storage (11-12 useable)
JellyFin server hex-core i5 (gen10) 28 GB RAM
I am assuming your Dell has ā€œbetterā€ hardware because is newer, Am I correct?
My backup device - i.e. to backup other servers and MacBooks - is a RPi4 with 8 GB RAM - 1 TB USB 3 boot SSD, and 2 x 6 TB USB 3 HDDs for backup (latter 2 connected to the Pi via powered USB 3 hub).
I use my MacBook Pro with Ubuntu (16GB + 1TB SSD) for Java/Spring development
louyo1
We have had very good luck with Dell refurbs … … …
Interesting your long feedback, pls could you share the URLs (if exist) of your servers? if is not possible consider to share the specs
Thanks to all for your time and support :penguin: :clinking_beer_mugs: :nerd_face:
If you want expansion provision, a tower is better.
If you want quiet and small use a mini.
There are also SFF towers … in between… eg Dell Optiplex.
I have a refurbished Optiplex … it is a fine Linux machine.
Note : this e-bay for Australia - not sure how useful it would be to you… Pretty sure it was a straight $400 when I got it in December 2025…
https://www.ebay.com.au/itm/205224913244?mkevt=1&mkpid=0&emsid=e11412.m144671.l197929&mkcid=7&ch=osgood&euid=b7240520d6c343cf900523a0e37b4214&bu=44220118408&exe=0&ext=0&osub=-1~1&crd=20260106001912&segname=11412
I’ve also already share the specs elsehwere on this forum but :
  • Dell Optiplex SFF 7080
  • Intel i5 (gen10)
  • 16 GB DDR4 (single stick - has 4 slots)
  • 256 GB SATA SSD (the specs vary a bit - mine came with a 2.5" SATA SSD not an NVMe - and I haven’t even looked at the board to see if it has an NVMe slot)
Again Big thanks for the replies
Understood… new term learned: SFF … I am going to do a research about the difference between SFF and Mini
Could you share its link and specs? What Distro is used and why?
Dan
Big thanks for the link!
Intel i5 (gen10)
Again big thanks!
