Are Documents/. and Documents/ the same?
I use it without the dot… it copies all the files including dot files.
Not the same as Documents/*
What does the dot do? I thought that you omit the trailing slash when transferring the actual directory. So would the /. just transfer the contents so that you do not end up with $DESTINATION/DESTINATION folders at the target?
Thanks,
I think so. / and /. seem to have the same effect… ie they transfer the contents not the folder.
We should wait and see what @daniel.m.tripp says.
/* is different… it transfers the contents too, but omits dot files.
Applies to tar too, not just rsync
Essentially “Documents/” and “Documents/.” are the same thing…
But I just append the “dot” “to be sure, to be sure”…
So “cp -r $SOURCE/. $DESTINATION/.” ensures I’m copying the contents of one to the other - not the “object” itself… It’s probably overkill I agree…
In this case “.” means the contents of the dir… and assumes $DESTINATION exists…
And yes - pretty much the same case for cp (-r), tar and rsync - probably cpio too (haven’t used that for decades now - but - DEB files are actually cpio archives)… these days I only use tar and rsync - I’ve done benchmarks - tar through a pipe, is always faster than rsync…
Lets say we’ve got a folder called Important, we want to copy it’s contents to somewhere else (e.g. to a mounted NFS filesystem) - e.g. bkup-important (NFS mounted at /mnt/bk-important). First time round, I’d use tar to “populate it”.
cd Important ; tar cvpf - . | (cd /mnt/bk-important ; tar xvpf -)
Then a tad later - when I want to refresh it with more current data :
rsync -av Important/. /mnt/bk-important/.
I’ve verified tar is faster - when migrating some 30 TB of customer data from one NAS (NetApp) to new NAS (Nutanix AFS).
There may be a case to be made for using compression - e.g. over a slow link :
cd Important ; tar czvpf - . | (cd /mnt/bk-important ; tar xzvpf -)
rsync -avz Important/. /mnt/bk-important/.
Both tar and rsync are inherently more bullet-proof than “cp”. I’ve found cpio nearly as good - but as mentioned above haven’t used cpio for decades…
But probably easier to just use rsync in the first place - as that pipe to STD-IN can get a bit fiddly and easy to mess up…
It is called ritual.
It helps the world to function, including the computer world.
Yes
If we had rsh it would also be the best option across machines.
tar -cf - -C srcdir . | rsh otherhost tar xpf - -C destdir
used to be common practice
Thanks for that , it is a good summary of how to copy stuff.
@daniel.m.tripp thanks for that great explanation. I have put those steps in my Linux notebook as it was easier to understand than some articles I’ve read.
Although I knew what tar was, I did not know how to use it and that will definitely help on getting over 500 gb of files to the new nfs-server.
Thanks,
It’s also so I know the result… e.g. if either side (folder) doesn’t exist - it won’t run… that’s good… Means I did something wrong and need to rethink it… e.g. create the destination… find out if I have permissions etc…
