I hate to say it, but getting Linux into the hands (PC’s) of most people is just a pipe dream. Meaning it will never happen. And why? Well, I believe the reasons are listed in your first post.
My opinion - I DON’T CARE that (desktop) Linux isn’t more widely used.
While we’re in this limbo of being “niche” product users (i.e. Desktop Linux - it already won the server war a decade ago!) - we’re less likely to be targetted by trojans, viruses and ransomware (don’t say never!).
Happy to be a niche user…
I agree with @Daniel_Phillips - if you don’t want to use Linux - don’t… I’m not going to try and talk you into it.
But I’m loving what Valve / Steam are doing - even if I can’t buy a SteamDeck in Australia… I’m sure it will inspired some non-Linux users, who are lucky enough to own a SteamDeck, to try out Desktop Linux - and it has vastly increased the number of Top Shelf PC game titles, that will run on Linux (using Proton [which is basically optimised Wine]).
Not by choice… That’s like saying everyone else, who don’t use Android, i.e. Apple iPhone users, chose to adopt FreeBSD (and samething for Playstations - they run FreeBSD, and I think Nintendo use OpenBSD?). Android only uses the Kernel - it’s NOT GNU/Linux…
But it is not classified as a Distro!!! It is really a propretary OS, just built using a Linux kernel. We can chose Linux distros, but if it is an Android phone, then it will have the Android OS.
You can get Android x86, for your desktop.
Is that not a distro?
Does not have to be FOSS to be a distro?
You should give it a try… might convert you off Win.
The reason why an ad campaign matters is fixing the issues mentioned in the first post… and on top of that getting more hardware support for Linux.
At the moment it’s kind of hit or miss regarding desktop Linux, unless you buy specifically from one of the Linux hardware distributors (which are few). Usually these options are more expensive than just getting a Windows machine, wiping it, and installing Linux… but then it’s possible you run into hardware issues.
Making people more aware of Linux as a desktop option may only be the first step needed.
We may then have to demonstrate that Linux is either different or does the same job better.
Scanners, printers and other peripherals are a big sticking point. HP has HPLIP built in to most distributions. It detects your printer automatically and handles old printers that Windows has dumped. But it doesn’t provide the same facilities as Win/Mac. Epson has Linux drivers but I don’t know what they do and there is no support.
My wife is the same, she has 2 computers on her desk but always goes to use the windows one, then complains it will not print, its slow, its doing a update,
My reply is use the linux computer its faster, safer, it prints, you choose when it updates ,
who am I to insist or know best
@callpaul.eu
OK!!! My wife is running software, for her hobbies that only Windows will run!!! With 16GB of ram and W11 booting an NVme, it is not slow, and updates are no problem!!!
So to keep her happy, she gets Windows!!!
