This line is missing a closing bracket in your frontend, Iâm thinking this might be the reason its failing for youâŚ
antix@antix-init-diversity:~
$ sudo 66 -z tree status -go name,contents
Contents :
ââboot@system:system-hostname (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:mount-run (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:mount-tmp (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:populate-sys (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:mount-pts (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:mount-shm (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:populate-dev (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:mount-cgroups (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:system-sysctl (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:udevd-log (pid=362, state=Enabled, type=classic, tree=boot)
ââboot@system:tty-earlier@tty12 (pid=271, state=Enabled, type=classic, tree=boot)
ââboot@system (pid=up, state=Enabled, type=module, tree=boot)
ââboot@system:populate-run (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:populate-tmp (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:mount-branch (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:system-hwclock (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:system-random (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:udevd (pid=463, state=Enabled, type=classic, tree=boot)
ââboot@system:udevadm (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:system-fontnkey (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:system-fsck (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:system-branch (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:mount-rw (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:local-time (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:local-loop (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:mount-swap (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:local-sethostname (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:local-authfiles (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:local-dmesg (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:local-branch (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:runtime-branch (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:canopy (pid=up, state=Enabled, type=oneshot, tree=boot)
ââboot@system:tty-rc@tty2 (pid=1100, state=Enabled, type=classic, tree=boot)
ââboot@system:tty-rc@tty1 (pid=1101, state=Enabled, type=classic, tree=boot)
Contents :
ââdbus-log (pid=1034, state=Enabled, type=classic, tree=global)
ââseatd-log (pid=1038, state=Enabled, type=classic, tree=global)
ââslimski-log (pid=1031, state=Enabled, type=classic, tree=global)
ââconnmand-log (pid=1042, state=Enabled, type=classic, tree=global)
âânmbd-log (pid=1045, state=Enabled, type=classic, tree=global)
ââsmbd-log (pid=1046, state=Enabled, type=classic, tree=global)
ââufw (pid=up, state=Enabled, type=oneshot, tree=global)
ââbluetoothd-log (pid=1048, state=Enabled, type=classic, tree=global)
ââelogind-log (pid=0, state=Disabled, type=classic, tree=global)
ââsshd-log (pid=1049, state=Enabled, type=classic, tree=global)
ââdbus (pid=1058, state=Enabled, type=classic, tree=global)
ââseatd (pid=1061, state=Enabled, type=classic, tree=global)
âânmbd (pid=1075, state=Enabled, type=classic, tree=global)
ââsmbd (pid=1064, state=Enabled, type=classic, tree=global)
ââsshd (pid=1079, state=Enabled, type=classic, tree=global)
ââconnmand (pid=1090, state=Enabled, type=classic, tree=global)
ââbluetoothd (pid=1089, state=Enabled, type=classic, tree=global)
ââelogind (pid=0, state=Disabled, type=classic, tree=global)
ââslimski (pid=1077, state=Enabled, type=classic, tree=global)
