Snapper btrfs snapshots on Gentoo, need pointers
Here’s the flags for openrc at the moment:
Local copy of remote index is up-to-date and will be used.
These are the packages that would be merged, in order:
Calculating dependencies             ... done!
Dependency resolution took 4.49 s (backtrack: 0/20).
[ebuild     U  ] sys-apps/openrc-0.55.1::gentoo [0.54.2::gentoo] USE="netifrc pam sysv-utils sysvinit unicode -audit -bash -caps -debug -newnet -s6 (-selinux)" 0 KiB
Total: 1 package (1 upgrade), Size of downloads: 0 KiB
!!! The following binary packages have been ignored due to non matching USE:
    =sys-apps/openrc-0.55.1 -sysv-utils
NOTE: The --binpkg-respect-use=n option will prevent emerge
      from ignoring these binary packages if possible.
      Using --binpkg-respect-use=y will silence this warning.
well it seems to be an Hyprland issue. I first tried to update Hyprland and keep the OpenRC on older version. The same issue, Hyprland wont work.
Then I reversed the order and all is working. So new OpenRC and older version of Hyprland is ok.
 emerge --info | grep openrc
sys-apps/openrc:           0.55.1::gentoo
 genlop hyprland
 * gui-wm/hyprland
     Fri Oct 25 10:23:29 2024 >>> gui-wm/hyprland-0.42.0-r1
Clever trick
It seems like fiddling with OpenRC is not going to help.
You have the sysv flags with openrc… might as well leave it alone… we dont need to look for trouble.
I once put runit into my Gentoo… just to see if I could do it… it worked but I went back to OpenRC.
Hyprland is new… it is not surprising the issue is there… you cant do much except wait.
Yes, I’ve masked the R2 version of Hyprland now. Hyprland is developing so quickly that it’s “normal” to have hiccups. That’s why I have X11+Cinnamon also
