Solus stuck during Install
" Installing in a VM works."
Does the VM have more space than your disk?
A hard install will load more drivers than a VM
Ok, could you perhaps try setting your VM to UEFI… or maybe set your machine to legacy boot?
Works. In VM.
Well posted there, no change
Do you mean works with UEFI in VM?
Yes. VM disk size same.
OK… we can conclude you are setting up UEFI install correctly
Therefore the fault has to be the disk.
Does the disk have a GPT partition table? … or is it MSDOS partitions?
It’s GPT type.
That is good, Solus needs GPT for UEFI
Are you making an EFI partition and a / partition during your install
Yes. EFI 1024 MB, fat32, boot esp flags. Root 240GB, ext4.
That sounds correct.
Did you mount the root and ESP partitions ?
Yes. EFI on /boot and root on /.
Maybe try EFI on /boot/efi ?
I am not sure what Solus requires.
Solus requires /boot, says otherwhise wrong mount and only will format.
OK, that is unusual… most distros use /boot/efi
It will obscure the previous contents of /boot
I can not see any mistake in your install.
We have to check the disk.
Can you use smartctl on the disk and show us its output please.
SmartCTL does not work, as I don‘t use NVME… the target device is the classic /dev/sdX,
Oh found how to.
==START OF INFORMATION SECTION==
Vendor: SSD
Product: SanDisk 3.2Gen1
Revision: 1.00
Compliance: SPC-4
User Capacity: 250‘148‘290‘560 bytes (250 GB)
Logical block size: 512 bytes
Serial number: —-
Device type: disk
Local Time is: Sat Aug 30 17:22:51 2025 CEST
SMART Support is: Available - device has SMART capability.
SMART support is: enabled
Temperature warning: disabled or not supported
== START OF READ SMART DATA SECTION ==
SMART Health Status: OK
Current Drive Temperature: 0C
Drive Trip Temperature: 0C
Error: counter logging not supported
There is no information
Did you do smartctl -a /dev/...
Yes, smartctl -a /dev/sdb.
OK, we cant do the disk check properly.
Another thing that may be causing it is the Solus drivers.
Lets start with network connection. Are you using WiFi to connect to internet?
Yes. My Wifi adapter is Intel.
Is there any option to try an install with another network interface as the primary network interface… eg do you have an ethernet port and could you use a cable?
What I am trying to do is test if the wifi drivers are the problem . By substituting another interface you get different drivers.
