Hello, How can I stop MTP (Media Transfer Protocol) on Ubuntu 16.04? Kindly help, if you know the answer?
One easy but not so clean idea would be to remove MTP libraries. No MTP support, no MTP connection
OK, I will try this and let you know
It’s perfect, working now. Thank you so much.
sudo apt-get purge libmtp-common*
Dirty solutions always work
