I never really got to understand why a simple CLI is regarded as less friendly than a GUI.
Perhaps because I grew up with BSD Unix where the only thing available was a CLI, sometimes on a teletype rather than a screen. Before vi, line editing on a teletype or a simple screen was quite a challenge.
Well something thats perhaps slightly tangental to that is that when people talk about friendly they also talk about accessible. And CLIâs are hard to make more accessible than guis. (english-only commands, keyboard centric approach, hard to work with files in, lots of tools and shortcuts to memorize or have handy somewhere). So I get where people come from with their dislike for CLIâs, but I think framing it as ânever seeing a terminal everâ means that a distribution is âbegginer friendlyâ doesnât orient us in the right direction either.
All we were trying to do with that list was give users a guide as to which distros might be a suitable choice given their level of experience.
I guess what Iâm trying to add is that âbeginner-friendlyâ might not always mean âno terminal useâ, but maybe how intuitive the recovery/configuration/daily use feels to someone whoâs casually using the system.
Some distros feel easier even with terminal use just because the systemâs behavior is more transparent or the documentation is clearer. So maybe, the âamount of hand-holdingâ or âquality of feedback when things go wrongâ could be interesting extra layers to add.
Want some terminal work!!! Try compiling LFS!!!
When you have mastered LFS, try compiling FreeBSD from source.
BSD is an easier build than Linux.
I am now compiling LFS in a VirtualBox VM, using W11 as my host. Did not know I had to have the âwhichâ command installed and showing in â/usr/bin/whichâ for the vbox-guest-additions to work. Working on dependencies for ânssâ, which is required for âfirefoxâ!!!
Maybe try a low level window system this time⌠like Fluxbox or Enlightenment.
After you have built a system in a VM, I wonder is it possible to extract it and make it a hard install?.. There would be driver issues and a filesystem reconfigure, but it should be possible. Want to try?
A suggested edit: there is an LFS version with systemd.
Thanks. Edit done. I need to fix the Markdown file too.
