@FBClark, I think I found it!
The forum motor plays havoc with my copy-paste
It automagiclly replaced my simple apostrophs to something opening, then closing apostroph:
tr -d ‘\015’
There should be only the simple (opening?) apostrophs.
If you can isolate a pair of your apparent duplicates into their own little file, and then pipe it into “od -xc” to dump it in hex and ascii, you may see hidden differences:
[kurt@T3400 ~]$ cat dupes
X Y
X Y
[kurt@T3400 ~]$ cat dupes | od -xc
0000000 0958 0a59 2058 2020 2020 2020 0a59 000a
X \t Y \n X Y \n \n
0000017
[kurt@T3400 ~]$
Thanks Kurt, I’ll put this in my notes. I got my problem solved by installing and using dos2unix.
Hi @FBClark
I edited the links in your original thread because it was leading to an adult website. You were trying to blacklist it I think. I replaced it with example.com so that other members don’t click on it accidently, specially on a work computer.
I hope you understand.
