What do we like about Linux?
I have no idea about UUID but I imagine that since “everything is a file”, as long as the relative structure stays the same, it “just works!” regardless of the computer it is plugged in.
There is a very good reason: greed
I also do that.
In fact any installed Linux system can be booted using a USB to SATA adapter (useful when the internal disk is not so accessible) and this is also fantastic
This allowed me to recover data from many crashed Windows PCs to their grieving owners, until Microsoft started encrypting the data…
Encrypting data in a user’s drive is on the very grey border of security vs ownership…
in widows you can disable encryption if you dont want it .
Try doing that once it’s been accepted almost impossible
Strange i have done it a couple of times
The problem with Windows is that Microsoft likes to turn on settings – whether you like it or not – without notifying you with any update.
Yes they do and that should be illegal that they are in others personnel computers and change things to their liking .
When you have the knowledge to accept encryption you probably are wise enough to save your encryption key in a place you will remember later.
The problem is when you are not IT literate and you are in a rush to turn on your computer and suddenly a question pops-up “Do you want to make your data safe?” (or something similar). Most users will click Yes, Yes and Yes and will not save the encryption key. They just want to log in…
And now Microsoft can sell them a new PC if it fails to boot. That is how monopolies (of dishonest people, but are there any other kind?) work…
What disgusts me is not that Microsoft is greedy. Is that it doesn’t give a **it if people loose their unique memories and documents…
I meant bit locker now Microsoft turns it on in windows 11 pro i think and you can disable it in the settings.
It is odd that some people see Google and Meta as evil but trust all their data to be stored on the Onedrive servers owned by Microsoft… :thinking:
Take heart. All unethical things fail in the long run. Our longest surviving institutions are those that self-correct. Nothing does that automatically, it needs a feedback loop… some outside input.
Linux has feedback … it will survive longest.
I realy dont think they have all their data at Microsofts one drive . Some maybe but far from all.
Absolutly agree
