Have you considered using Docker, you could just spin up a container and use your web browser to edit, make anything you like. Here is a list.
Key points about office containers in Docker:
Popular options:
Some popular Docker images for office applications include "linuxserver/wps-office" (WPS Office) and "onlyoffice/documentserver" (OnlyOffice), which provide a web-based interface to edit documents, spreadsheets, and presentations.
You could probably run Win11 in a docker container in Linux i’m running docker compose but you can install docker-desktop or Virtualbox to run windows in a vm.
Hi Kerry,
I tried Windows 10 in virt-manager. It works but it is slow. I found Win7 faster so I use it in virt-manager, but only when I have to use Windows.
I dont think that will work. Docker is Linux thing. A container is just an environment without a kernel, it uses the host’s kernel.
I dont think Win could run on a linux kernel?
I think what you first suggested, …putting a linux word processor in a container is a good option. It would make it portable and would package it with any special dependencies.
A lot of home users have no experience with docker or any variety of containers.
It would be a learning curve.
There is a thing called distrobox which makes docker easy for beginners.
You might find this helpful, take a look at this, you can also run MacOS as well. The instuctions are clear and easy to understand…you can just use the run command which is listed or use the docker-compose.yml to add usr, passed, extra drives etc. I thought the same thing until I started using docker-compose you can run so much many different types of servers, media servers, os’s and use and automated proxy server that will auto add ssl certs for you using this or something similar.
so it is using QEMU, and has firefox inside qemu and win11 viewed on port 8006.
I had no idea what to do in Win11, so I stopped it… killed the tab and then used CtrlC to stop the container.
Then I could not work out how to restart the container. … if I use the original run statement it starts a download again. … I think I need docker start containername… look into that tomorrow.
It did Win 11 by default. There are lots of other options
I noticed one thing… it is more responsive than my Win7 in a VM.
Very interesting .
I wish someone else who uses Win would give it a try… you need to know how to drive docker.
I am personally more interested in trying the MacOS container.
Now stop it docker stop b33bbb9a0c1b
and Win 7 shuts down
Now start it docker start b33bbb9a0c1b
and I get Win7 back in my browser tab.
OK, I think I can manage that.
BTW that b33bbb9a0c1b is thecontainer number
[nevj@trinity Dockur-win]$ docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
b33bbb9a0c1b dockurr/windows "/usr/bin/tini -s /r…" 17 minutes ago Up 2 minutes 0.0.0.0:3389->3389/tcp, :::3389->3389/tcp, 0.0.0.0:8006->8006/tcp, 0.0.0.0:3389->3389/udp, :::8006->8006/tcp, :::3389->3389/udp windows
You can use numbers or names to refer to containers in docker commands.
OK, Now I want to try MacOS
I want to see if I can use distrobox instead of docker to run these containers… because most people would find distrobox easier than docker.
Is this actually “docker” when it needs kvm and/or qemu? It doesn’t seem to be a proper “container” if it’s using a hypervisor… e.g. FreeBSD jails and Solaris Zones don’t resort to using a hypervisor…
I made the mistake of trying to install docker (not from Pop or Ubuntu repos) on my Pop!_OS and trying this - but - it wouldn’t run 'cause I don’t have KVM hypervisor (I have VirtualBox hypervisor only). And after that - took me a bit to figure out how to remove it :
I may try this on my Ubuntu 24.10 laptop though… I assume you already had kvm installed (@nevj )?
What’s a real PITA is that in Ubuntu based distros “apt install docker” does NOT install the CLI / TTY binaries - so you think you’ve installed it - but YOU HAVEN’T! So you have to jump through a hoops in order to be able to run “docker composeet cetera”.
This is very interesting however - and I’m keen to have a go…
I was not aware Pop was without KVM… I thought it was in all linux kernels?
Yes, this procedure certainly uses QEMU… and therefore most likely KVM…
I have not fathomed exactly how it uses QEMU, but it is obviously needed to map Win system calls into Linux system calls.
I would like to see what you can do with this… it looks to be a better way of running Win(or Macos) than using VM.
I have no idea how to get software into Win so I cant really test it , but it is responsive on my machine( 2nd gen i7)
and in Debian the package is docker.io, not docker… watch that.
Maybe Ubuntu is like Debian?
Well , it is a terminal, but I can barely read the font size and it will not change.
BTW there is a warning
“by installing Apple’s macOS, you must accept their end-user license agreement, which does not permit installation on non-official hardware. So only run this container on hardware sold by Apple, as any other use will be a violation of their terms and conditions.”
I am not sure whether emulated Apple hardware counts, so be careful.
I think I will leave this to the Mac experts like @daniel.m.tripp
It seems to be.
That is one of the ways qemu gets a video display
" The web-viewer is mainly meant to be used during installation, as its picture quality is low, and it has no audio or clipboard for example.
So for a better experience you can connect using any Microsoft Remote Desktop client to the IP of the container, using the username Docker and by leaving the password empty."
Think a one off on home machine is unlikely to bring down the wrath of apple … ipolice tend to not look too close, too much work for icourt, ijudge, lawyers
I didn’t know about docker so tried it in Zorin which is Ubuntu based.
Had to jump through some hoops to get it working.
Just wanted to see how it compares to using a VM.
The laptop I use is reasonable spec, 11th gen i5 and 16GB ram.
I normally use virt-manager or gnome boxes for VM’s.
Can’t see any benefit using docker, it doesn’t work any better than a VM for me.
Maybe I didn’t set things up properly but did get W11 running in a browser and installed a couple of apps.
To be serious, I was on a computer forum years ago where a moderator stated he would never have i anything.
Obviously meaning apple products.
He didn’t state the reason why.
I am biased as I worked teaching at a college where we bought macs for the students, then when I was teaching at uni I set up a classroom especially with apple, to teach desktop publishing extremely popular had to run evening courses to get near the demand.
Afterwards I went to work for apple, 5 great years.
That was before imac, around the time of Next just before jobs returned
I currently use a macbook pro, but with linux as the mac os expired and not possible to upgrade. In my workshop I have 2 of the original powerbook portable macs, 2 years ago I donated a se30, lc 475, and a mac power pc to a museum for restoration projects, suspect the powerbooks will go the same way.
