Who uses AI and what do you understand about how it works?
The aim is to learn. By being very selective about training we should be able to limit its size and sphere of knowledge. Then we may be able to see how it deals with questions, because we would have inside knowledge of what it knows.
Have you seen any software that would allow us to train up our our LLM? It would mean statistical fitting of parameters to data.
I use CoPilot and the Google AI when building LFS, some things I agree with and some I do not, but keep the questions simple and on target, for the best results!! One has to also rely on one’s own knowledge, to get the needed results!!
Well said.
Could a poorly educated person use AI to build LFS … No.
With enough patience and determination one will eventually build LFS!! AI only gives answer’s the user has to apply the proper commands!!
That requires some Unix or Linux education.
I have no idea. All I can do is describe my experience using the AI Agents I have experience with. Sorry!
Ernie
When I don’t really have direct experience with whatever I’m trying to accomplish, I explain what I’m trying to accomplish with a prompt that’s as detailed and concise as possible, along with requesting a step-by-step guide, then I execute one step at a time, posting the result, regardless the outcome. That way I keep Gemini as on task as I can, and when we don’t get the expected outcome and I post the result, Gemini returns an adjusted command and further steps that will be compatible with the changes. I’ve achieved excellent results using this procedure, even if it takes longer. I, for one, am not concerned with the amount of time required to achieve a positive result. For me, it’s the result that counts.
Ernie
I disagree. With great desire and perhaps the help of a GNU/Linux user who has completed the task, I say it could be possible, albeit unlikely, and the scenario presented raises the question ‘Why would such a person prefer to go through all the effort of creating an LFS system would require when there are plenty of excellent distributions available.’
Ernie
Or the ability to request a step-by-step guide from your favorite AI Agent, and following it one step at a time. That’s how I got my LXC Container created that I use to store my Veeam Agent backup images on my Proxmox home lab.
Ernie
I see two paths. One much more difficult then the other.
Path one.
Build your own AI and provide the training. This option will entail a huge amount of effort, yet be the most rewarding in learning AI from A to Z.
Path Two.
Install a tiny / small AI that has already been thru the learning. Being small, it has a limited amount of training and still can be tested.
From my talk with AI about Path One..
And Path Two from AI.
The base LFS build already has a guide, no AI needed!! The why I build LFS, is simple, because I wish to build LFS!! Yes, there are other distros, but none build with open source, as does LFS!!
We probably should try path2 first.
That experience would help with path1
Lets find a small prebuilt model
[quote="Ernest N. Wilcox Jr., post:49,
topic:16043, username:ernie"]
[/quote]
Ernie , you have some considerable amount of Linux education.
When I built Gentoo, I had help from @4dandl4 . I had a previous try that failed. I dont think I would have succeeded without help … there is just too many things to learn all at once.
We did not have AI then. I am not sure if AI would have helped with Gentoo , because there are excellent manuals for getting information. The difficulty comes from having to learn many things all at once … it is a huge hurdle.
When you have done such a thing once, the information overburden disappears. Even if you forget details over time, relearning is easy. If you do it frequently, you dont forget… it becomes part of you. Then you dont need either help or information.
Thank you. The information you present id, in and of itself, informative, but I think there is more to the second, easier path, and that is to consider what you learn about the processes used, and that’s how I use existing AI Agents. I use AI to get things done that I don’t already know how to do, and when I request a step-by-step guide, the AI usually explains what each step’s intended to accomplishes, and/or why it’s needed. With these guides, I learn something about the thing I’m trying to do. For now, that’ll be good enough for me, but I look forward to following the progress if any other community members decide to attack path 1 :slight_smile: ,
Ernie
Please don’t get me wrong. I wasn’t minimizing the value of LFS. Rather I was questioning why someone who knows little about GNU/Linux in general, or who is less intelligent (as IIRC was what I was responding to in my previous post) would choose that route before becoming familiar with the OS first. I’ve tried LFS, and it’s very difficult, even with the guide presented. And to someone new to or unfamiliar with GNU/Linux, that guide may be useless because of how it’s written - for knowledgeable readers.
Ernie
I agree. That’s how I tend to use AI - more as a knowledgeable helper or tutor rather than a shortcut to achieving an objective where the AI does all the work for me. Although I use AI to accomplish objectives, I want more from the process that the accomplishment, I want to understand what has been accomplished. The advantage of AI is that I don’t have to clog Forums with my requests for help, or wait for a knowledgeable helper to come and sit beside me as I try to work through whatever it is I being helped with. AI’s right here on my computer whenever I need/want it.
Ernie
From part of me trying to understand AI better.
My understanding is that a token is a phrase … a string of X words. Right?
So if you string words together in the right order it looks like understanding ??
That math says … choose the token of largest probability conditional on all(?) previous tokens.
So it is conditional probability.
That is how it constructs a sentence.
I wonder how it interprets a sentence … ie how it deconstructs your sentence. It might just break the question up into tokens, then make them the start of the list of things it is conditional on?
The sequence of tokens is important. The tokens are ordered in a sentence. I wonder how it can be conditional on an ordered sequence of tokens.? I think there is maths that can do that … a hidden Markov model maybe. ?
I need to read more.
I need a review paper on the maths behind AI
Still here in the “managed” topic? :wink:
How about a new category about any AI topics? Over time, this appears to be reasonable for me.
Should I ask AI how to create one …
