GPT is certainly comprehensive the way it lists all possible cases
it seems to have overlooked the fact that this bug is specific to Margret’s hardware
We dont hear complaints from all over the world about updates causing boot delays.
Therefore it must be a hardware/software interaction.
That limits it to kernel modules, I think?
It is not worth the effort to try and track it further.
Thanks to @Rosika and Margret for an interesting problem
"This message began to appear when you upgraded to kernel 5.13.
SGX stands for “Intel Software Guard eXtensions” and is “a hardware-based isolation and memory encryption mechanism provided by modern Intel® CPUs”. In your BIOS you might find a switch with 2 or 3 possible options:
Disable: SGX instructions and resources are not available to applications
Enable: SGX instructions and resources are available to applications
Software Controlled: SGX can be enabled by software applications asking for it
If the option is not there you might get it through a BIOS upgrade. Otherwise, if you want to get rid of the message, add nosgx to the grub defaults (see How do I add a kernel boot parameter? on how to add a parameter). You can also safely ignore the message, as SGX is benign and not necessary."
Thanks a lot, Howard, for the additional info and for prividing the link.
Alas, Margret´s UEFI doesn´t list anything like that.
The message itself doen´t bother me, to be honest.
Like @nevj said:
Oh, I have to add that due to the excitement regarding the fact that everything worked well again, I forgot to check whether the message
“X86/cpu: SGX disabled by BIOS”
was still there. I may check it next time I am with Margret again.
