2º display detected but not working
Hello, I recently migrated from windows and started using Linux/Ubuntu.
Everything was going fine until I connected my notebook to a monitor/display.
Here is the config I am running:
Hardware model: SAMSUNG ELECTRONICS CO., LTD. 550XDA
Memory: 8 GB
Processor: 11th Gen Intel® Core™ i7-1165G7 @ 2.80GHz × 8
Graphics: Mesa Intel® Xe Graphics (TGL GT2)
OS: Ubuntu 22.04.1 LTS
OS Type: 64-bit
GNOME Version: 42.4
Windowing System: Wayland
As you can see the display was detected by the system:
Despite this my second screen is all black. I already tried it on another computer and it works just fine. The problem is something with this config. Maybe the graphics card? Mesa Intel® Xe Graphics (TGL GT2).
Can someone please help? I really need this setup working for my studies.
Thank you very much.
Welcome @Octavio_Garcia ,
Have you tried going back to X11?
Is Ubuntu fully updated?
You may get better drivers for the video card if you enable non-free software repository
Check your cables
Other than that, I do not know. I am not a video expert.
Sorry but what do you mean by x11?
Hi Octávio :wave:
The X Server is the user-side part of the X Window System. The X Window System (also: just “X” or “X11” or “X Version 11” - but not: X-Windows) is a collection of protocol standards and computer programs for creating a graphical user interface
(from https://wiki.ubuntuusers.de/XServer/ ; translated from German)
Hope it helps.
Many greetings
P.S.:
I guess what Neviile meant with
is that you should try an x11 session instead of a wayland session.
suggests:
if I log out, and then click on my name to log in, and it opens the password field - then there, on the lower right, a toothed wheel appears and there I can select another session.
It should work, I think.
Thank you very much for the explanation, but unfortunately changing to Xorg (X11) didn’t solved the problem. is there anything else I can do?
This may help
https://help.ubuntu.com/stable/ubuntu-help/display-dual-monitors.html
Also do a search with google. There may be others with the same problem
