Hi all, ![]()
does anybody of you use the 4G-stick Huawei E3372h-320 ![]()
If yes, I have a question about a specific point. Everything´s alright; I´m just asking out of curiosity. ![]()
In contrast to my previous stick (which was a MEDIONmobile Web-Stick (model S4012) = Huawei E1550),
the new one no longer logs on to the computer as a modem, but as a virtual network card.
A new LAN interface (“Kabelgebundene Verbindung 2”) is created and the computer connects to this one.
Internet connection itself is established using the stick via the browser. The respective page is “http://192.168.8.1/”.
Here a Huawei-powered GUI presents itself and I establish the internet connection by clicking on something like “connect”.
As far as the LED of the stick is concerned the manual says the following:
Indicator
It indicates the status of the USB Stick.
• Green, blinking twice every 2s: No service/The network
is not registered.• Green, blinking once every 0.2s: The software of the
USB Stick is being upgraded.• Green, blinking once every 2s: The 2G network has
already been registered.• Blue, blinking once every 2s: The 3G /3G+ network has
already been registered.• Cyan, blinking once every 2s: The LTE network has
already been registered.• Green, solid: The USB Stick is connected to a 2G
network.• Blue, solid: The USB Stick is connected to a 3G network.
• Cyan, solid: The USB Stick is connected to an LTE
network.• Off: The USB Stick is removed.
After the device is inserted into the USB port, the
indicator will turn solid green, indicating that the
software startup process has initiated. After the startup
is complete, the indicator works as detailed above.
That´s all clear so far.
Yet I discovered that this stick behaves somewhat differently from my ancient Huawei E1550 which worked as a modem (using ppp0 as inerface).
When connecting to a 3G-network the Huawei E1550 displayed a blue LED which stayed on during the entire time of connection.
However: when doing some up- or downloading the blue LED was a bit brighter. So you could easily tell whether the stick was just up- or downloading something.
In an “idle” state (“stand-by” so-to-speak") the blue LED was a bit darker.
Just to be clear: The LED was constantly on, just with different intensities.
Now with the new Huawei E3372h-320 it´s different.
When a connection to a 4G-network (it´s the same with 3G) is established the LED lights up with consistent intensity. It doesn´t matter whether or not the stick
is in the middle of an upload or download process or whether it´s just in an idle state. The LED-intensity remains unaltered.
So my question to anyone using the Huawei E3372h-320 would be: Is it the same with you ![]()
Many thanks for your opinions in advance and many greetings from
Rosika ![]()
P.S.:
Internet connection with the Huawei E3372h-320 is generally rock-solid.
It only once occurred that the Huawei E3372h-320 disconnected itself from the 3G network. This was during a pretty severe thunderstorm with heavy raining and hailstorm.
As far as I can remember the connection re-established itself after a while as soon as the weather conditions were better.
