I have run into a problem that I haven’t been able to solve. My Optiplex Micro 750 began running slowly, so I purchased a refurbished Optiplex Micro 7050. Newer, fancy NVMe SSD, even smaller case (18x18x4 cm). Powered it up, let it install Windows11, rebooted with a bootable install disk of MODICIA OS. Installed with no difficulties, wiping out Windows. Everything worked–wifi, printers, sound, you name it.
I removed the 1T 2.5 inch drive from the older computer, slid it into the connectors, and rebooted it. MODICIA started normally. GParted showed me that the 1T drive was present and contained the 5 distros it had in the old machine. I processed Grub-Customizer (I know, I know) and rebooted the new machine. Grub’s menu showed all 6 distros (OS prober worked!) and subsequently I was able to run all 6 without problems.
I decided to de-install one of the distros to make room for Garuda, to give it some more attention. GParted wiped it out, leaving 200G or so of empty space. I created a bootable install USB of Garuda and booted it. Colorful! Started the installer, watched Calamares start, and went to offload some coffee and pour a fresh cup.
Calamares was waiting for a module–for 6 minutes it had been waiting.
Secure Boot was off. The SATA option was AHCI. There was a UEFI partition. No luck.
I have tried every setting change in the BIOS that I can find. Fedora has a different graphic, but it acted like Calamares.
Is the problem in the machine? in the BIOS? in Calamares? is there another installer I could try? I haven’t consulted any of the AI machines yet, preferring to throw the question onto the ItsFoss dissection table and let you folks show off your smarts and your experience.
The good news is that the machine works, with 5 interesting and functional distros available. Gnome Boxes works on most of them, so I can browse live ISOs almost as much as I’d like. I can manage this way for a long time, until I get the itch to try to figure it out. Thankfully, I can still walk, so I can shoulder my bag and play 9 holes any time She Who Must Be Obeyed allows.
But I’m still curious.
