And here is my attempted replacement, which unfortunately doesn’t work:
curl http://www.bacula.org/downloads/baculum/baculum.pub | gpg --dearmor | sudo tee /usr/share/keyrings/baculum.gpg > /dev/null 2>&1
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0
gpg: no valid OpenPGP data found.
Unfortunately, the public key is not available, so either the above command hasn’t worked properly, or I have made an error somewhere else.
sudo apt-get update
Err:5 https://www.bacula.org/downloads/baculum/stable-11/debian bullseye InRelease
The following signatures couldn't be verified because the public key is not available: NO_PUBKEY E72D44EC5C3DBD51
Hit:10 https://www.bacula.org/packages/651c57a54dffa/debs/13.0.3 bullseye Release
Reading package lists... Done
W: GPG error: https://www.bacula.org/downloads/baculum/stable-11/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY E72D44EC5C3DBD51
E: The repository 'http://www.bacula.org/downloads/baculum/stable-11/debian bullseye InRelease' is not signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration details.
The issue was my initial attempt at configuring the list file.
Here is the correct configuration:
deb [signed-by=/usr/share/keyrings/baculum.gpg] http://www.bacula.org/downloads/baculum/stable-11/debian bullseye main
deb-src [signed-by=/usr/share/keyrings/baculum.gpg] http://www.bacula.org/downloads/baculum/stable-11/debian bullseye main
