I don’t know which terminal application you are using.
Most terminal applications are somehow derived from the good old xterm which supports the -e command flag. xterm -e bashtop instructs the system to open a xterm window and to run the bashtop command in it. Try it out!
If you’re using, say konsole, the command you have to run at startup (or login) would be konsole -e bashtop
You can do that via one of the methods described in the document, you linked. My choice would be crontab @login
Unfortunately, it’s still not working on LM20 while using Terminator or GNOMEterminal.
Luckily, this was just curiosity exercise and not something critical.
I appreciate you all giving it go. Thank you.
@edgrin2 I’m sorry to hear that it didn’t work. xterm and konsole both did it on KDE. I don’t have Gnome, so I didn’t try gnome-terminal but according to the man page it should work if you add it to the Startup Applications:
gnome-terminal(1) User Commands gnome-terminal(1)
NAME
gnome-terminal - terminal emulator for GNOME
DESCRIPTION
gnome-terminal is the GNOME terminal emulation program. It provides
access to the UNIX shell on the GNOME environment. [...]
OPTIONS
The following options are supported:
-e, --command command
Executes the command command instead of the shell. This saves some
memory if you just plan to run a dedicated application on that win-
dow.
EXTENDED DESCRIPTION
gnome-terminal is designed to emulate the xterm program provided by the
X Consortium.
I appreciate your help. I went with the Gnome-terminal route since I already had it installed. Terminator terminal just couldn’t get the job apparently.
