Stetp By Step Guide Needed for Installation of andriod studio please help me out!!
It is available in Ubuntu Software. Search for it and one click install
You can fine the Snap version in the Software Center.
Reference:
Although @abhishek has given the answer to you and therefore this really has been solved. If you want to be helped by the community, a screen shot really really is not enough information. If this had been the only post I would have been totally confused as to what you asking about. So please if you require help, add specific details, for example what OS you are using as well as the problem. That way the whole community can help. Thank you
There is a typo I can see.
You can use the command line if you want:
sudo snap install android-studio --classic
