I know this is a Linux forum but as many of us also have a tablet and Android wonder if anyone has come across similar issues and found a solution
Screen ghost
bought a Lenovo tablet m10 the tbx606f been using it without issues
But during a internet connection yesterday the tablet begain a strange bleeping sound and a load of rrrrrrr appeared on the search bar I was not touching the screen or keyboard at this stage when that stopped my screen changed and it’s now ok left hand side but the righhand side is a off set image of left
Hard to describe
But it’s as if the screen is being duplicated but off set by 3 inch imagine underneath the t letter I can see a q under the y I can see a w etc
Thought at first virus issue so scanned with several different virus tools malwarebytes AVG avira etc all found nothing
Android Google scan from play store found nothing
I tried a restart same problem
I went to settings and did a factory reset same problem
I tried a hard reset with power and sound control but this comes up in Chinese or a similar language set which I cannot follow and I am unsure in case it is a different order to the English help sit info
Of course now out of warranty by 2 months
Would have to scrap it so looking for ideas
Appreciate your help
