Any new options for mic not working on zoom, cinnamon
So, you’re running Zoom in your web browser, and not the Zoom app itself? I’m using the Zoom app.
I’m using the Zoom app, not web. The browser is the problem, the settings I show allows the mic to work within the Zoom App.
After opening Zoom and going to test audio, slide the mic volume to zero then back to your normal vol settings you use. Also make sure the 'automatically adjust ’ is not selected.
Linux mint (21.3 cinnamon) user here. Zoom flatpak. No problems.
I have an asus pn50 minipc and a logitech usb hd camera with built in stereo mic. Zoom remembers my configuration and I never have any problems.
Solved. We got rid of the older Logitech webcam and replaced it with a new one. :smiley:
