Anyone ever jailbreak a Kindle for KOReader? Thoughts?
I got a free Kindle recently. It’s a KT6 with v5.18.6 firmware. I quite fancied the idea of using KOReader, but unfortunately neither of the well-known jailbreak methods work on this device/firmware combo.
But I’m curious; has anyone installed KOReader on a Kindle? What was your experience like? Any perks aside from the adbreak?
Trying to decide if it’s worth nabbing an older Kindle to play with.
Cheers!
Frost
This seems to say that it is a relatively easy task.
https://www.notebookcheck.net/A-guide-to-jailbreaking-and-installing-apps-on-your-Kindle.1207399.0.html
Yeah, I think if I had either the firmware version below or a non-MTP device, it would be super easy. Like good ol’ JailbreakMe 3.0.
My issue seems to be MTP KT6s on v5.18.6 aren’t compatible with winterbreak or nosebleed. Unfortunately, there doesn’t seem to be a public jailbreak for my particular model/firmware combo. This device is MTP rather than mass-storage USB, which seems to blooter a lot of the relied upon exploits. And then it came preloaded with v5.18.6, and I can’t see a way to rollback firmware on a stock kindle that wasn’t already jailbroke.
(sidenote: what is the past tense of jailbreak? Is there a consensus? :thinking:)
My intuition says “jailbroke”
What is jailbreak? What is KOReader? My kindle is 12 years old and works great.
Mine too, though I did briefly toy with ‘jailbroken’ before I posted.
Jailbreaking is essentially just bypassing the restrictions set by the manufacturer to install custom software. KOReader is a FOSS document viewer for e-ink ereaders. I’d generally rather run FOSS software on my devices, plus there’s a lot of interesting extensions and customisations available for a jailbroke Kindle.
Thanks. My old Kindle keyboard will do fine until it expires without modification.
I have jailbroken my Kindle to run KOReader and it’s absolutely worth it - KOReader is much better than the inbuilt Kindle software - no ads, much more configurable, runs faster, uses less battery, the list goes on. You won’t regret it. I am using a Kobo Aura One now with KOReader because I wanted the bigger screen. So I’d say it is worth getting an older Kindle and jailbreaking it to run KOReader.
Interesting timing; Amazon just announced they’ll be dropping support for older models (2007 -2012). It’ll still work, but seems we’ll need to sideload.
Cheers Russell; that pretty much confirms all the reasons I wanted it. I’ll see if I can possibly swap it with someone who has an older model. In the mean time, I’ve kept it on aeroplane mode to prevent future updates.
Yeah it looks really easy and the result seems super convenient; just unfortunate that my model/firmware combo isn’t compatible with Nosebleed or Winterbreak (KT6 on firmware v5.18.6).
Although its not jailbreak this item may act as a guide
I just read an item in today’s (04/09/2026) ZDNet: Tech Today newsletter that on May 20, 2026, older Kindles (released prior to 2013) will stop working, in that you will no longer be able to purchase books. In the same newsletter, I saw this item about jailBreaking older Kindles. I don’t know if it’ll help, but have a look. Maybe it contains a resource that may be useful …
Ernie
I’m really curious if it’s that easy, because I am looking to get a color Pocketbook running Linux, but I didn’t find any second-hand one at a lower price, so I might get a Kindle instead, as they’re so much easier to find.
Saw this today from ZDNet about how to jailbreak a kindle.
I’ve been playing around with this recently trying to figure out why it doesn’t work. Essentially, the known methods for jailbreaking rely on access to system/.assets to inject the exploit payload. The older models exposes the full user storage filesystem over UMS, so you can see everything the kernel exports. But the new kindle’s device’s object enumerator literally just filters out that directory.
There is a 0.43s race condition where the kindle loads in UMS mode before the MTP daemon starts, but even if you catch it in PID 0x0324 mode with timing tools, .assets still isn’t exposed. Same with OpenMTP and the likes. I guess it’s filtering at the gadget driver’s configuration or a custom filter/overlay in the kernel gadget code itself?
I just put mine in aeroplane mode so it does not connect to the internet and it works fine, but out of that mode it is unable to open any books I have installed.
I did think of a reset to factory defaults having copied all my books off first. Then setting it up without a account but it will not let you use it without registrations and that re connects you.
Not sure about jailbreak maybe just better to get another make when this one stops
I just bought a new one to replace my 16 yo one. I’ll probably not mess with it but just use it.
Great news, new jailbreak has been released for KT6.
I was using a Kobo (Aura?) for a few years… I’d easily “side load” un-DRM epub files using Calibre (on Linux)… But it got restrictive - e.g. some book not available at Rakuten Kobo bookstore - only Amazon or Google… Never figured out / or got working / decrypt strip DRM from Amazon or Google ebooks… So I couldn’t read them on my Kobo… At one time - I had a windows laptop at work and found a DRM removal tool - which sorta worked, but unsatisfactory and didn’t always work…
Nowdays?
I use an iPad Mini (5th or 6th gen?) - and I can open epub files directly - or - copy / upload them into my Google Play account and read using the Google Books app for iOS - or buy from Amazon Kindle and read in Kindle app, or even buy from Kobo and read in the Kobo app…
I can also read the same books in Google Books on my phone if I don’t have my iPad mini handy…
I have an automation thingie running on the iPad that switches to low power mode whenever it’s not hooked up to a charger… Can go for days and day without charging…
