Anyone tried Mainstream os
Has anyone tried this Distro its arch based with Hyperland desktop i did try it and i have never used Hypeland desktop before i did like it but its so much that needed to be customized almost every application window like firefox and the terminal started in full screen and i rely dont like that , if everything had been as most Distros i would have tried it longer. just to paste something was like i never had seen before you paste text with middle mouse button. I might give it another try it was very different then im use to.
That is the standard Unix way of doing it.
It is quite convenient … you can copy and paste with one hand on the mouse.
Hyprland is a tiling window manager. If you open two applications they will be side by side. You can find a lot of dot files for Hyprland. The dot files are how you can customize the look (and other things like shortcuts) of the window manager.
OK thanks :slight_smile:
