Hi, just wanted to ask does any of you guys use a WM instead of a DE in your distro, i personally use awesome window manager
its great and i use this configuration from chris titus tech https://github.com/ChrisTitusTech/material-awesome
And i think its good for begginers moving from a DE
Hi Kitt, never heard of this WM, but have hear a person can run into problems replacing one DE with another one. Does WM run independent of the DE or replace the one that came with the Distro?
It is independent by default and can easily be logged into as any DE
Hey I’m using i3 window manager. Use his config, and it’ll be a lot easier. It’s amazing. Finally found a person of my kind.
