I’ve created a fork of ubuntu-settings(gnome-control-center) for adding the ability to fully switch themes to light, standard and dark and also included some of the common dock-options under dock section. I’ve used it on ubuntu 20.04 and ubuntu 21.04.
I’d like to know whether this helps others ? should I get this into a PPA? or does this need more dock-options ?
The code for Settings(gnome-control-center) is hosted on launchpad. So I just yeeted the code from there added the new-options and pushed on github (I should definetly add that this a fork in README to avoid this confusion. thanks for bringing this up)
Thanks @Akito, I think I’ve added all the common-options that people seem to be wanting. I’ll looking into getting this upstream probably next month-ish.
Is there way you could add testing tag to this thread? I can’t seem to edit the tags for this thread
Sorry but I won’t try this because I’m happy with the default features - and when I want to tweak something I just run gnome tweaks…
But mainly I won’t try this because it breaks my “golden rule” :
NEVER INSTALL PPA’s
too many bad experiences in the past with them - i.e. breaking “apt update”… and too many times I’ve been called on to support a Debian or Ubuntu server that some developers have completely utterly toasted by adding PPAs (even attempted to fix some issue on a debian system by reading some Ubuntu forums and installed Ubuntu PPAs on ancient versions of Debian)…
