Best desk speakers for a reasonable price?
I’m in the market for a new pair of speakers, as my current ones have recently shown signs of breakage in the cables.
My new speakers need to produce a reasonable sound quality and I think sturdy cables are a good idea. I need stereo speakers - I’m not looking for surround sound. I also don’t want a subwoofer. I just want two speakers which will occupy one port. Bluetooth, infrared, or wifi speakers are also not an option for me.
Which do you recommend in the price range €100 - €250?
What are the usage, if I may ask?
Are you looking for speakers to keep on your computer desk?
Yes, desktop usage.
My vote goes for Microlab Solo 6C if you can get it. Otherwise try to get an affordable bookshelf speaker set, and an amplifier for it. In the long run that will perform better than the speakers intended for computer usage. I currently have a pair of Magnat motion 110, that’s a closed box (not vented!) so the bass fades much more naturally than with a bass-reflex system.
I’m more than happy with that, and I can recommend a similar setup.
If I had the money then my only answer would be BOSE, now whats the question ?
But they are expensive and depends what you are going to listen too and at what level.
I have alex a very early version no longer sold. Its on wifi and I am happy listening to the radio on it as background. My stepson plays games and uses a soundbar plus bass driver, the room shakes when he plays. Lucky he lives 150 km away so no big problem for us just people in the same apartment block as him.
I have these speakers and love them. Klipsch ProMedia 2.1 THX Certified Computer Speaker System (Black). But they have a subwoofer. About $180 US.
I have not used these, but I am guessing they would be similar in quality to mine. Klipsch ProMedia 2.0 Multimedia Compact Computer Speaker System Compatible for Any Laptop, Desktop, or Mobile Device for Premium Home Office, Workstation, or Gaming System (Black). About $130 US.
The best thing about aging might be that my ears don’t really care about sound quality any more. Or maybe I was never very picky. I find speaker systems for $10 or less at the local thrift store.
Mine never did, but now I can hardly hear the speaker that is built into the screen. Do you think addon speakers would help… the machine does have an unused sound card.
With out a doubt yes !
I also have this one. It doesn’t sound as good as the Klipsch but it’s a cheap option you might like.
onn Bluetooth 2.0 Channel Soundbar with Multi-Color LED Lighting, 20", Black
The ‘onn’ brand is Walmart’s own brand. It’s small 20.00 x 3.15 x 2.52 in (508.00 × 80.01 × 64.01 mm). It has an audio in jack, USB in, and optical in. $34.88 US.
