Best linux distro for HP victus 15 fa1xxx?
I’m currently installed pop os 24 LTS version but it’s looks like so limited due to the recent cosmic DE changes and issues like suspend resume, firmware are there. I’m a student studying CS and learning programming and other technical stuff. So for this I need all the technical software that should be compatible for linux which I installed. Now I’m currently have a mind to move to linux mint or looking for best distro available for my specs.
HP victus 15 fa1xxx specs:
  • 8gb ram
  • i5 13th
  • nvidia RTX 2050
  • 512gb ssd
Hello and welcome to our site.
I would always recommend Linux mint to new linux users as it covers all the requirements without any pain or problems. It comes in several flavour and my personal choice would be linux mint debian edition LMDE.
It has the cinammon desktop and so looks and feels just like the cinammon version, but tends to be more flexible.
The mate version has an old look and feel but again would be very capable
The xfce version tends to be more limited and is more suitable for lower spec machines.
But you will not go wrong with any of them.
No doubt my fellow members will offer alternative suggestions……
Is linux mint cinnamon best for my laptop specs? I need your suggestions please
Yes as I said
But sources telling it was not for modern hardware is it true..
No idea what other sources you have and if they are more informed, but personally I never have a problem with mint or linux.
Best answer i can give is download a copy of the iso and burn a dvd or usb, then try booting to that. You will then know if it works on your computer and if you like the interface. This ça be done without changing your current system.
Then choose to go forward with it or not
Any of the Debian based distros will be fine for those specs, and Debian-based will also suit your student work. That leaves a huge choice … Debian, Mint, MX, and many others.
Those specs may not support use of a VM. You need to check if the cpu supports virtualisation, and you need to ensble it in the BIOS.
Other than VM, that 8GB machine should run any Linux well.
Linux will run faster if you choose a modest desktop environment … eg choose Xfce or LxQt rather than Gnome or KDE. It is up to you… there is a tradeoff between speed and fancy features.
8 GB is a decent amount of RAM - but - not ideal…
But everything my esteemed colleague @callpaul.eu stated is probably good advice - MATE or Cinnamon (both of which I believe are forks of Gnome 2?) - you’ll get a modern looking interface, but it probably less resource hungry than recent Gnome 4x or KDE…
Your best shot is probably LMDE with Cinnamon desktop…
Me? I’d probably still run Ubuntu 24.04 on that hardware… I’ve run Ubuntu with full Gnome 4x desktop on a Raspberry Pi4 and a Pi5 (8 GB RAM) and didn’t notice any performance issues - but it wasn’t my “daily driver”…
A lot of @callpaul.eu 's users he supports use MINT and they have no need to use the shell or “bash” or “Terminal” - me? I find there’s so much richness in the shell - that’s where I prefer to do most of my “work”…
I won’t run Pop!_OS 24 because Cosmic is still too “new” - with a whole bunch of teething issues and probably severely locked down and no tweaking tools for power users (and I need x11 / xorg - and I’m pretty sure Pop!_OS 24 with Cosmic is Wayland only)…
Been called some things in the past (usually not repeatable), but never been esteemed before … thanks for that.
Or if you want a true non-systemd build Gentoo OpenRC!!
That is not the only way to get a non-systemd distro?
The easiest non-systemd distro is probably Devuan. The most innovative is antiX. They are both Debian based. MX is somewhere in between.
In Arch-based systems, the best non-systemd distro is Artix.
Gentoo as a non-systemd distro is faultless, but it only offers OpenRC init system.
Void is similar … it only offers runit init system.
Maybe not, but that is what I use!!!
Perhaps you can name some of these so we can advise further if they run or you need alternatives. Depending on where you are a student if they have guidelines you need to follow.
Is anybody using linux on HP Victus 15 if that I need your usage review and how you benefited from..
I have an HP Laser Jet 1102 and an HP Envy Inspire 7200, one pretty old and one brand new. Both run flawlessly on Linux Mint Debian Edition, Cinnamon.
I also like and would recommend Linux Mint. You might also want to consider MX Linux.
MX has an “ahs” release for “Advanced Hardware Support release for very recent hardware”.
There are other reasons for using Gentoo apart from getting a non-systemd distro
  • you learn a lot about linux
  • by compiling you optimise your linux for your hardware
  • portage is a really great package manager
  • it is fun building your own system
  • its software repo is as comprehensive as Debian
  • it is more up to date than a fixed release distro
  • it may support very new and very old hardware better
Can you think of any other reasons?
Sorry, this is getting off topic.
There are also reasoms for not using Gentoo
  • it takes a lot of time
  • it ties up your computer with long compile jobs
  • one has to learn a whole new package system
  • the install is more difficult than most other distros.
  • you have to use CLI
The pros and cons balance out.
I am running LM on a Lenovo Thinkpad with an i5-1135G7 with no problems. I had one problem streaming movies over WiFi, but it get resolved.
If that is the case, not sure linux is the answer without further technical info.
Why don’t you just try an USB iso for Ubuntu? If it works (like wifi, YouTube, sound etc) it works. It doesn’t cost you anything to try.
