That was a failure. It could not find my original.
I will have to upload it again.
Talk about wasting peoples time.
Uh, that´s rather unfortunate.
With me I see 3 entries:
- System assigned profile picture
- Gravatar, based on [e-mail address]
- Custom picture
So I assumed your personal picture would be there as well.
Sorry, Neville. ![]()
Cheers from Rosika ![]()
That is what I see, but gravatar does not work, and custom picture is that graphic with dots and Uâs.
I see an upload button next to âcustom pictureâ.
Can´t you upload your picture this way - again?
Sorry, Neville. But that´s all I can think of⌠![]()
Yes, that is what I have to do. Finding the picture might be a challenge.
I see.
I´d suggest: go to: https://avatars.githubusercontent.com/u/22612586?v=4
and take the picture from there (possibly with a screenshot).
Hope it helps.
Well, besides buying a new flash drive (stick), it looks like you have another solution to the boot problem. Insert the stick after you have booted the PC. Simple and no cost.
Kind Regards,
Howard
Hi Howard, ![]()
thanks for the suggestion. ![]()
That´s a solution, of course. I admit I wouldn´t have thought of that. ![]()
Well, as long a s the stick doesn´t produce any other errors that´s something worth considering.
Still: I guess it might be a good idea to save all the important data from the stick as long as it´s readable.
Thanks again and many greetings from Rosika ![]()
